It is currently Sat Jan 20, 2018 3:29 am
Visit Thermo worx
PostPosted: Wed May 10, 2017 10:05 am
Has thanked: 1 times
Hi guys
I'm relatively new to DIY and in particular home electrics. I've just moved into a new house and need to replace a ceiling rose in one of the bedrooms - seemed straight forward enough and I figured it would be a good place to start.
I've removed the cover and am faced with the picture in the attachment. As I'm an amateur I just wanted to check my thinking really:
  • I believe that there are two colouring schemes here - the red/black from the house wiring and the brown/blue from the ceiling rose down to the bulb-holder.
  • This appears to be a different/older style of ceiling rose with the terminals arranged around the casing, rather than in a line like all the examples I see online. I assume that the principles are still the same!
  • I assume that the earth cable is held in the plastic block.
  • I'm a little confused as to which terminal block is serving which purpose. The top block has a brown wire down the bulbholder and the bottom block has a blue wire down to the bulbholder, so I would assume they are 'live' and 'neutral' terminals respectively. However both also have a black wire into them, rather than the red and black (respectively) that I would expect. There is a red wire going into a single terminal block in the lower right of the photo and then back out again. Is this the loop? Any help on unpicking this would be much appreciated!
Now that I look at the photo I think I need to do some more poking around in there to identify all the cables better.
Feedback and advice much appreciated.
Cheers
Andy
File comment: Ceiling rose internals
PostPosted: Wed May 10, 2017 10:20 am
UHM Super Moderator
Has thanked: 170 times
Been thanked: 554 times
I'll move this to lighting.
PostPosted: Wed May 10, 2017 4:39 pm
Has thanked: 36 times
Been thanked: 1153 times
Label them before you do anything.
The reason you have "two colour schemes" on the wiring is easy. Flex (That is going to the lamp holder) changed to the "new colours" many years before twin and earth changed colours.
The single black should have red tape on it as it is switched live
The two blacks are neutral
You are lucky you only have 2 cables that rose is the last one on the run, open another rose you should find 3 cables, each with 3 wires.
The two reds are live.
Do a search on this forum for "changing a light" (or similar) as what "you expect" and how its actually done are two different things. What you have is correct, oh and you are right about the rose being old style.
For this message the author someone-else has received gratitude : andymh
PostPosted: Mon May 15, 2017 7:22 pm
This was a big help, thanks. Job done.
PostPosted: Mon May 15, 2017 8:29 pm
Approved Electrician
Has thanked: 147 times
Been thanked: 520 times
So why two black neutrals? If this was the last one on the run then there would be only one black neutral.....
