Page 1 of 1
[ 3 posts ] |
| Author |
Message |
nursedave
Posted: Sat Feb 26, 2011 8:47 pm |
| Newly registered Member |
Joined: Sat Feb 26, 2011 8:37 pm Posts: 3 Has thanked: 3 times Been thanked: 0 times
Hello there plastering forum! Am currently putting in new bathroom. Place was a bit of a mess. Have taken off old skirting boards successfully on 2 walls, but on one of them, some of the old wall has come off too, exposing the brick behind. The original plaster me thinks. Whats the best way of filling this new gap in? Should I use pva on the wall before I put any filler in? Type of filler to use (was a wide array in B&Q earlier)? Your advice on this would be appreciated!
Ta very much!
| Top |
jozeffo
Posted: Sun Feb 27, 2011 8:18 am |
| Senior Member |
Joined: Tue Dec 02, 2008 7:52 pm Posts: 2448 Location: South London Has thanked: 58 times Been thanked: 272 times
Bonding plaster, thistle undercoat plaster or harwall. PVA first, then get a good coat on but dont be fussy. Leave it half and hour and it will stiffen so you can flatten it out. If it still isn't right, apply a second coat after about an hour.
| Top |
register or
log in
nursedave
Posted: Sun Feb 27, 2011 10:25 am |
Cheers for that! I appreciate the advice. Will let you know how I get on.
| Top |
register or
log in
Page 1 of 1
[ 3 posts ] |
