Page 1 of 1
[ 15 posts ] |
| Author |
Message |
TheApprentice2011
Posted: Tue Jan 03, 2012 6:40 pm |
| Senior Member |
Joined: Tue Jan 04, 2011 2:59 am Posts: 308 Has thanked: 19 times Been thanked: 3 times
What is the advantage of nylon wall plugs over the standard plastic type ones, are they stronger or more weather resistant. Cheers
| Top |
fin
Posted: Tue Jan 03, 2012 6:45 pm |
| Senior Member |
Joined: Wed Apr 16, 2008 7:49 pm Posts: 1563 Location: south tyneside Has thanked: 0 times Been thanked: 66 times
to be honest i never knew there was a difference. i just buy rawl plugs or equivalent makes as and when i need em. isnt a lot of stuff thats plastic "nylon" anyway?
| Top |
register or
log in
register or
log in
register or
log in
fin
Posted: Tue Jan 03, 2012 9:01 pm |
| Senior Member |
i just drill holes and use brown plugs where needed and red where needed. or grey where needed. though they are usually supplied with things like hand basins etc.
never have much bother with most plugs. certain makes seem better than others though so i always try to buy makes i know from past use.
| Top |
register or
log in
Hitch
Posted: Tue Jan 03, 2012 9:14 pm |
| Senior Member |
Joined: Mon Jan 16, 2006 8:16 pm Posts: 4673 Location: Somerset Has thanked: 6 times Been thanked: 108 times
I use the cheaper nylon ones most of the time, not like the fischer ones in the link above. http://www.toolstation.com/shop/Screws% ... 060/p24478I find they seem to take screws better, they feel tighter when putting the screws in.
_________________ Why isn't the number 11 pronounced onety one?
| Top |
register or
log in
upagumtree
Posted: Wed Jan 04, 2012 9:39 am |
| Senior Member |
Joined: Sun Feb 20, 2011 4:35 pm Posts: 981 Has thanked: 2 times Been thanked: 103 times
The plugs that I linked to are universal and can be used in solid materials such as brick and concrete but they can also be used in plasterboard and light blocks. All the other links point towards plugs only suitable for solid walls. As building materials change the fixings market/technology has moved on as well
| Top |
register or
log in
register or
log in
register or
log in
TheApprentice2011
Posted: Wed Jan 04, 2012 5:26 pm |
| Senior Member |
Used them to hang a bathroom cabinet on a dot and dab wall they say if the gap is 10mm it can hold upto 200kg( not including tv mounts that have arms due to leverage)
| Top |
register or
log in
upagumtree
Posted: Wed Jan 04, 2012 5:32 pm |
| Senior Member |
I use them for curtain poles and the like in rental units as the tenants always seem to be heavy handed
| Top |
register or
log in
TheApprentice2011
Posted: Wed Jan 04, 2012 5:38 pm |
| Senior Member |
I only got a 8 pack as I was not sure about them, how do you get on with them and what else have you used them on.
| Top |
register or
log in
jg
Posted: Wed Jan 04, 2012 8:04 pm |
| Senior Member |
Joined: Fri Mar 13, 2009 8:32 am Posts: 744 Location: Bucks Has thanked: 15 times Been thanked: 43 times
I use fischer brown plugs for just about everythig except real plasterboard cavities. If dot & dab I just push the plug through the PB and use a strong screw to hang whatever i'm fixing. If i'm worried about the weight I put half a second plug in the PB to support the screw. If it's something really heavy, and won't be seen, I cut out a section of PB and fit a wooden block directo to the blockwork. (used this method for TVs and Radiators. HTH J
_________________ I am not a pro.
| Top |
register or
log in
upagumtree
Posted: Thu Jan 05, 2012 5:48 pm |
| Senior Member |
TheApprentice2011 wrote: I only got a 8 pack as I was not sure about them, how do you get on with them and what else have you used them on. Shelves and curtain track/poles mainly, there planned useage is for TV's but I haven't put one up yet. Never had any problem with them
| Top |
register or
log in
upagumtree
Posted: Thu Jan 05, 2012 5:52 pm |
| Senior Member |
jg wrote: I use fischer brown plugs for just about everythig except real plasterboard cavities. If dot & dab I just push the plug through the PB and use a strong screw to hang whatever i'm fixing. If i'm worried about the weight I put half a second plug in the PB to support the screw. If it's something really heavy, and won't be seen, I cut out a section of PB and fit a wooden block directo to the blockwork. (used this method for TVs and Radiators. HTH J I have used both those methods back in the olden days Much easier to drill one hole, pop the plug in, fix the screw, job done. but each to their own
| Top |
register or
log in
Page 1 of 1
[ 15 posts ] |
