It is currently Fri May 25, 2012 6:46 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
PostPosted: Tue Dec 06, 2011 3:23 pm
"LIFESTYLE" Mid-position valve has gone across to the "H" setting , And I,m sure the little black lever on the side of the box used to stick out the further than that ? -
And shouldnt the indicator be in "M" position?? ,
how do I get it back to normal.
Blsck lever appears to be stuck ?
any help much appreciated.
PostPosted: Tue Dec 06, 2011 3:46 pm
OAP
Has thanked: 187 times
Been thanked: 2114 times
Does the little lever pull out a few mm
PostPosted: Tue Dec 06, 2011 4:37 pm
UPDATE on earlier post - Now mY radiators are RED hot even tho the thermostat is set down to 15 C, why ?????
PostPosted: Tue Dec 06, 2011 4:42 pm
Has thanked: 166 times
Been thanked: 613 times
:dunno: Do you mean this post
post419317.html#p419317
And if so what have you done (If anything) since?
PostPosted: Tue Dec 06, 2011 7:46 pm
Yes sorry , - what seems to be happening is I think that 3 way thingy is sticking. I turned the thermostat right down , yet the boiler was roaring away and the radiators were RED hot , Does that 3 way thing , supposed to direct the flow in another direction , once the set temp has been reached , mine just got hotter and hotter. If that 3 way was in some way defective , what would happen ??
PostPosted: Tue Dec 06, 2011 7:50 pm
Has thanked: 76 times
Been thanked: 373 times
Thanks for the link Wine O :thumbleft:
Have you done as Scruff suggested and tried to pull the arm out a few mm allowing it to return to the hot water position where it would normally live?
If it won't return by spring now then turn the heating off at the power supply and try it again.
Let us know how you get on.
And yes they certainly can stick but that's not the only possible fault :wink:
PostPosted: Tue Dec 06, 2011 8:06 pm
HOLD EVERYTHING , have found pages of info from guy with identical problem , and loads more with similar problems - from older forum posts , and theyve given me loads of info - Thanx , probs should have checked that at the beggining before posting - sorry guys and thanks again.
PostPosted: Tue Dec 06, 2011 8:10 pm
No worries, check back and tell us how you got on :salute:
PostPosted: Tue Dec 06, 2011 8:33 pm
Has thanked: 51 times
Been thanked: 230 times
Change the valve for a Honeywell. Drayton controls are nothing but trouble
:cb
Dave
www.drlgas.co.uk
PostPosted: Tue Dec 06, 2011 9:04 pm
UHM Super Moderator
Has thanked: 24 times
Been thanked: 63 times
I've managed to merge both of your threads together although I haven't got a clue how I did it :lol:
Mod 6
