It is currently Tue Jan 16, 2018 5:43 pm
Visit Thermo worx
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
PostPosted: Sat Oct 14, 2017 9:03 am
Has thanked: 9 times
Been thanked: 1 times
Hello.
I'm a first time home owner and I bought a house with dodgy looking electrics but a good looking boiler.
Anyway - I just had the place rewired throughout and when I moved back in, the boiler has no pressure so I have no heating. The pilot light is on and it still fires up and sounds perfectly normal.
At my last house, my landlord showed me which screw to turn to increase the boiler pressure - but if it's the same with this one then I have no idea what to turn! There are so many more pipes!
I took some photos of the boiler and pipes, could you please help?
On the boiler there is aslo a reset button and a spanner button. The reset button makes it go silent for a few seconds then refire up again and the spanner button doesn't seem to do anything.
PostPosted: Sat Oct 14, 2017 9:09 am
Has thanked: 745 times
Been thanked: 794 times
In your top pic you can see a white plastic 't' shape 'key' sticking down.
This is the filling loop key. The filling loop is built in on these boilers.
This needs to be turned 90d, possibly may have to be pushed up a bit first, then the white plastic knob beside it turned as well, I think that is the one, then the pressure should increase.
Fill to around 1.25 Bar, turn off both valves and remove the plastic key.
Dave
www.drlgas.co.uk
For this message the author gas4you has received gratitude : spellingisnotmyfort
PostPosted: Sat Oct 14, 2017 11:10 am
Has thanked: 297 times
Been thanked: 913 times
Bit worrying that the key is permanantly in place Dave :lol: :lol:
PostPosted: Sun Oct 15, 2017 9:20 pm
Thank you for your help. I got the pressure up to 1.25 bar and then turned on the heating and no heat. The boiler sounds like it's working but the big blue light on the front started flashing after a couple of minutes and the light by the flame symbol is not on. I then tried increasing pressure to 1.5 and 1.75 bar but still the same thing.
Does anyone know what I can do?
The electrician rewired the central heating wires last week. Is this something I need to get them to look at again?
Or am I to call a plumber?
Just so you know, things I have already checked are:
Gas works to the gas fireplace downstairs (boiler is upstairs)
The thermostat is on highest and the timer is set to be on 24hours a day.
Thanks all.
PostPosted: Sun Oct 15, 2017 10:01 pm
Has thanked: 153 times
Been thanked: 92 times
Thanks all.
If it has been rewired recently and hasn't worked since.....there's your answer
For this message the author Ktuludays has received gratitude : spellingisnotmyfort
PostPosted: Sun Oct 15, 2017 10:03 pm
Is the blue light flashing fast or slow, on an off or off and on?
Dave
www.drlgas.co.uk
PostPosted: Mon Oct 16, 2017 12:02 am
I posted a quick video here:
https://streamable.com/swn1w
It seems mainly off and then flashes on. Maybe five times in 4 seconds.
PostPosted: Mon Oct 16, 2017 8:03 am
Don't know these boilers too well, but from the instructions that is pointing to either a faulty sensor, fan or internal wiring problem.
You need to get your boiler man back to look over.
Dave
www.drlgas.co.uk
For this message the author gas4you has received thanks - 2: multiman, spellingisnotmyfort
PostPosted: Mon Oct 16, 2017 1:33 pm
Thanks. It was an electrician just doing a house rewire which I had round before. I suspect he did not touch wiring inside the boiler. He probably just rewired the thermostat, timer and plug/fuse. Do you believe its unlikely to be his fault?
PostPosted: Mon Oct 16, 2017 3:48 pm
If it worked ok before the rewire I'd be looking there 1st. It's the only thing that has changed so I'd start there with the electrician revisiting
PostPosted: Mon Oct 16, 2017 7:25 pm
Check live and neutrals haven't been reversed somewhere after his work.
Dave
www.drlgas.co.uk
PostPosted: Mon Oct 16, 2017 7:50 pm
Have you ever had the heating working?
The system could have been completely drained down and the boiler could be overheating due to air.
As it's a new house to you I'd recommend you get an RGI in, tell him what's happening and arrange to have the boiler serviced at the same time
For this message the author Razor has received gratitude : multiman
PostPosted: Sat Nov 04, 2017 4:23 pm
Update time. The electrician kindly came back but could find no fault with his own work even though it was working immediately before they started the rewire.
So I had a plumber/ registered gas person come out and he diagnosed the problem as being a faulty boiler fan.
£300ish from my own pocket later and it's sorted with a new service thrown in too. Thanks for your help everyone.
For this message the author spellingisnotmyfort has received gratitude : gas4you
PostPosted: Mon Nov 06, 2017 6:29 pm
Has thanked: 696 times
Been thanked: 28 times
What rates is he charging
PostPosted: Mon Nov 06, 2017 6:38 pm
Has thanked: 1357 times
Been thanked: 3502 times
How is that relevant Multiman ?
