It is currently Wed Aug 15, 2018 12:32 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
 Post subject: No nuts solution
PostPosted: Mon Aug 24, 2015 10:22 pm
Has thanked: 22 times
We have an exercise bike and the nut and bolt have worn down. I cannot get any spare parts so I need to join the nut and bolt via some other method. I've considered soldering but this is a working moving part so I doubt that will work. Any solutions?
Alex
 Post subject: Re: No nuts solution
PostPosted: Mon Aug 24, 2015 10:48 pm
Has thanked: 94 times
Been thanked: 348 times
Is it just a standard nut and bolt??
A picture is worth a thousand words....can you upload a picture of the broken part, and a picture of where it goes on the bike?
PostPosted: Mon Aug 24, 2015 10:49 pm
I will get one and feedback :)
Cheers
PostPosted: Mon Aug 24, 2015 11:30 pm
Here you go :)
http://my.jetscreenshot.com/22337/20150824-vmnx-116kb
PostPosted: Tue Aug 25, 2015 5:47 am
Has thanked: 44 times
Been thanked: 1303 times
(Makes life easier, when the pic is in the post)
Any chance of another that is in focus?
PostPosted: Tue Aug 25, 2015 11:08 am
Has thanked: 70 times
Been thanked: 84 times
Hi are you saying that the threads on the bolt have worn so you can't get a nut on ?
PostPosted: Tue Aug 25, 2015 3:42 pm
Has thanked: 1098 times
Been thanked: 1024 times
As already said, you need to post a shot that's in focus so the detail can be seen.
Soldering won't work.
PostPosted: Tue Aug 25, 2015 4:44 pm
Has thanked: 51 times
Been thanked: 530 times
Drill it and put split pin through it, a few washers to stop it going anywhere
or
Pull the bolt out - turn it in a lathe and turn it down, re cut the thread the next size down
or
Drill the end of the bolt, tap the hole out and stick a bolt in the end
it look more like a cross trainer - body sculpture ??
PostPosted: Tue Aug 25, 2015 5:38 pm
Thanks for the replies :)
Sorry I cant get a photo to upload directly. http://my.jetscreenshot.com/22337/20150825-in9p-105kb
Falsh yes its a cross trainer thing not sure of the exact name. Is it easy to drill metal?
PostPosted: Tue Aug 25, 2015 5:41 pm
I can't open the link but why can't you go to you're local hardware shop and get a bolt and some washers and just replace it ?
Read the post about posting pictures you will get more help if we can see
PostPosted: Tue Aug 25, 2015 5:43 pm
UHM Super Moderator
Has thanked: 176 times
Been thanked: 605 times
Easy to add pictures.
PostPosted: Tue Aug 25, 2015 5:57 pm
Thanks for the pic mod2
Looking at that I would get a new but the correct size probably a nylon locking one , clean the threads on the shaft wind nut on then using a cobalt drill bit drill through the nut and lock in place using a split pin
PostPosted: Tue Aug 25, 2015 6:13 pm
Well it says Marcy on the side :roll: A quick google shows the Marcy brand is owned by Tunturi
http://www.tunturi.com/support/ Have you tried them for spares ?
edit. a quick google search shows it to be a Marcy xc50
PostPosted: Tue Aug 25, 2015 7:47 pm
Yes it is for you and me, but alexb123 (The OP) has only 9 posts, he can't add pictures untill he has a post count of 10
PostPosted: Tue Aug 25, 2015 7:57 pm
UHM Super Moderator
Anyone can add pictures. As evidenced here hole-in-silk-emulsion-t80419.html#p662753
He can't post links until 10 posts.
