Ultimate Handyman Home
No difference in speed
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Power Tool Reviews -> Makita
ProfPlum
Junior Member
PostPosted: Fri Nov 16, 2007 10:32 am    Post subject: No difference in speed Add User to Ignore List Reply with quote
I have just bought a Makita 8390 DWEP3 18V drill/driver (2 speed setting) but when I set the speed to "1 Low" which is supposed to be 0~350rpm and then check the no load speed at "2 High" which is supposed to be 0~1200rpm, there is no difference in the sound therefore I guess there's no difference in speed. Is this faulty? Has anyone had the same problem?
Back to top
jason123
PostPosted: Fri Nov 16, 2007 3:23 pm    Post subject: Add User to Ignore List Reply with quote
Are you sure the speed selector has moved properly, they can hover around the middle sometimes not fully engaged in the different gear. Hold onto the chuck on the two speeds, you should feel the difference.
Stella Stella Stella oy oy oy
Back to top
Hitch
PostPosted: Sat Nov 17, 2007 6:12 pm    Post subject: Add User to Ignore List Reply with quote
Can you see a speed difference?
The sound from the motor will be virtually the same, as that spins at a set rpm no matter which gear it is in (without load)
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Power Tool Reviews -> Makita All times are GMT
Page 1 of 1
