It is currently Thu Feb 09, 2012 9:45 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject:
PostPosted: Thu Nov 05, 2009 8:48 pm
diesel demon
Has thanked: 13 times
Been thanked: 12 times
will ask tomorrow
i love being married
my favourite things
 Post subject:
PostPosted: Thu Mar 11, 2010 5:35 pm
Has thanked: 8 times
Been thanked: 9 times
took the plastic front off the machine, as it had frozen in the shed :oops: Got a blow heater on it, and 1/2 hour later, worked again. So, its also survived being frozen..........
Had a look for the minor oil leak (previous post), but it was so little, I just wiped the casing clean, and will look again after a few days of use.
Only thing that was wrong when i took the case off, was the internal hose is slightly too long, so was chaffing on the plastic casing, and the protective rubber covering of the hose was almost through to the metal.................. a bit of leccy tape solved that one.
If you have one of these machines, I would check that, as a bit of tape is cheaper than a new hose :roll:
www.craigthehandyman.com Wilmslow / Alderley Edge
 Post subject:
PostPosted: Thu Mar 11, 2010 8:18 pm
diesel demon
i was going to ask if you'd drained it over winter as we've had a few fecked ones come into the workshop, mainly BRENDAN units.
they are good machines but the ones we get have the yanmar engine because honda have stopped making the 9hp diesel engine, we also get the frames galvanised
we had a run on brass ball valves with the side blown out of them due to frost, mostly 1/2" & 3/4" but also had a couple of 3" & 4" ones
my favourite things
PostPosted: Wed May 26, 2010 3:17 pm
Thats it, I've had enough of bloody pressure washers ::b
This ones has went to heaven after 1 year 2 months of intermittent use. The motor is sticking, and as the pressure washers main part is the motor, its as good a scrap (spares or repair) I will phone back the service agent and ask them for a price of a new motor, but i cant see it being under £200, so I wouldn't fix it.
Got dm tools to phone Nilfisk to ask if it can be fixed under "not fit for purpose" and Nilfisk say no.
Hopefully the lost sales from people finding this thread on google will loose them a lot more than the £430 I've wasted on it :cb
PostPosted: Wed May 26, 2010 6:16 pm
diesel demon
hang fire Handyman, i'll ask at work if there's a scrapper i can rob
my favourite things
PostPosted: Wed May 26, 2010 11:08 pm
cheers for that..........if not, its getting burnt :angryfire:
PostPosted: Thu May 27, 2010 8:23 pm
diesel demon
spoke to workshops, they think it's the wobble plate that's seized, it happens when it runs short of oil, i think you mentioned a leak?? to confirm take the pump unit off & motor should spin
i can pm you my number & you can give me a call tomorrow if neccessary
my favourite things
PostPosted: Thu May 27, 2010 8:56 pm
Has thanked: 151 times
Been thanked: 509 times
Just as a matter of interest...WTF is a "Wobble plate"??
PostPosted: Thu May 27, 2010 9:04 pm
diesel demon
it's a plate on the motor shaft that is off perpendicular, a sprung loaded plunger off centre but in line with the shaft would be forced in & out
my favourite things
PostPosted: Fri May 28, 2010 7:26 am
Motor is out, and its tight to spin, as if its out of center. Hope it wasnt the oil, is it not meant to be a sealed unit? When i looked, it had 1 drop of oil on the ground. Opened and cleaned inside, as there was a slight misting of oil on the casing, used for mabye 40 more hours, looked again, and it was still clean. To me, its dropped 1 teaspoon of oil in over a year.
On the other hand, it could have dropped all the oil (before i seen the drop) when it was sitting on grass, and I wouldnt have seen it.
And even worse, if I had seen this then, it would have still be under warranty :cb (the makita 131 also dropped all its oil)
PostPosted: Fri May 28, 2010 9:39 pm
diesel demon
it's only a small amount of oil, about 18ml if i heard the boy right
my favourite things
PostPosted: Fri May 28, 2010 10:42 pm
fixable?
PostPosted: Fri May 28, 2010 11:30 pm
diesel demon
without seeing it i'm not sure, i was told there was a wobble plate kit available, i'll speak to the guy on monday
how far were you able to strip it down?
my favourite things
PostPosted: Sat May 29, 2010 7:27 am
At the moment, the motors out, and thats it.
PostPosted: Sat May 29, 2010 7:32 am
Has thanked: 65 times
Been thanked: 330 times
I understand how frustrating it is when tools let you down :cussing:
But would it be dead if it hadn't been frozen and used without oil in it :scratch:
