It is currently Mon Jul 16, 2018 7:54 am
PostPosted: Thu Jul 20, 2017 7:01 pm
Has thanked: 16 times
Hi Guys,
does anyone know where I can get some spares for a Niagara Shower cubicle? I think that they may have gone out of business, I found
http://www.niagarabathrooms.co.uk/
So I contacted them and they responded buy saying that they don't do shower cubicles, they just took over the name.
What I need is a Corner cap, it's not square, it's a curve, I've attached a few photo's.
Many Thanks
Steve
File comment: With broken cap back
File comment: With broken cap top
File comment: With broken cap front
File comment: Inside
File comment: Front
File comment: Top
PostPosted: Sat Jul 22, 2017 7:12 am
Has thanked: 1452 times
Been thanked: 3723 times
You'll be lucky to find any spares, might be worth a look on "the shower doctor" (Google)
For this message the author wine~o has received gratitude : stevec59
PostPosted: Sat Jul 22, 2017 12:39 pm
Thanks for the reply, I was beginning to think that I wasn't going to get any replies.
I had contacted
www.showerpart.co.uk
Who claim to do a 'Matching Service' where they match your part up with what they have, but they don't have anything, so I'll try your suggestion and see how I go.
For the time being it's glued with Epoxy Resin and that is holding, I managed to get a better join, so the cracks aren't so bad, and I put some sealant around the bottom.
If I can get a 'Bend' is there another easy cheap fix, or is it going to have to be a new enclosure, I guess £100 - £200 as it's not to big.
Again,
Steve
PostPosted: Mon Jul 24, 2017 4:32 pm
Unfortunately 'The shower doctor' doesn't do spares for shower enclosures or cubicles, so not sure wher else to try, think I'm gonna be stuck and have to get new enclosure
PostPosted: Mon Jul 24, 2017 4:43 pm
Has thanked: 1072 times
Been thanked: 1006 times
What about mending the existing with epoxy and wire ties to strengthen the join? Let the wire into the surface using a Dremel to cut the grooves, then "vee out" the cracks and fill with "Milliput" coloured to match existing, or paint the corner pieces all the same colour.
I've mended quite a few "unmendable" plastic items using a similar method. Might be worth a try?
For this message the author Dave54 has received gratitude : stevec59
PostPosted: Tue Jul 25, 2017 4:44 pm
Thanks , I might give it a go or P38?
PostPosted: Tue Jul 25, 2017 5:39 pm
I've used that a time or two and filled the voids with it where possible inside plastic mouldings. If you can "key" (scratch it up to give a bit of grip) the inside, and get a reasonable thickness of filler behind the cracks you don't need the wire to strengthen.
Good luck with it. :thumbleft:
PostPosted: Tue Jul 25, 2017 7:50 pm
Make sure it's degreased as well with meths or similar. Gives a better hold. (If you haven't already done it that is)
Some plastics "glue" better than others though.
