It is currently Wed Jun 20, 2018 11:23 pm
PostPosted: Tue Aug 15, 2017 7:42 pm
Been thanked: 1 times
Hi there,
I have just fitted a new light in the kitchen. There is another light I am also fitting in the kitchen that was working. I took the light down and drilled two new holes to fix a new light. Now strangely when I turned the electric back on the new light did not work.
I then proceeded to fit the old light as I knew that was working. This also now did not work. I am not sure what has happened, I am really stumped. The cable goes straight up into the joist and I drilled to the side of them. I don't believe this light is fed from the other light in the kitchen as they are grey sheathed cables with red and black and earth cable. The light I now have a problem with is 1 white sheathed flexi cable with blue and brown and earth cable. There are no other cables, just one twin and earth.
I am unsure how I went from a working old light to now no working light at all.
Do you guys have any suggestions, please?
Thanks.
Col.
PostPosted: Tue Aug 15, 2017 8:01 pm
Has thanked: 696 times
Been thanked: 28 times
You will need a meter to check voltages
PostPosted: Tue Aug 15, 2017 8:46 pm
There clearly is no voltage or the light would work.
PostPosted: Tue Aug 15, 2017 8:56 pm
Has thanked: 11 times
Been thanked: 56 times
A neutral or live could have come adrift and the flex is maybe in connectors which could have come loose.
PostPosted: Tue Aug 15, 2017 9:02 pm
Has thanked: 1050 times
Been thanked: 977 times
Probably. Nothing is ever that simple with electrics. I have actually seen cases where a working item has been replaced with a new faulty item. The original when refitted had also become faulty possibly due to handling. :dunno:
So you check the voltage just to be sure. It will probably be zero, and the fault something like Morbius suggests, but you should approach fault finding methodically. :thumbleft:
PostPosted: Tue Aug 15, 2017 9:31 pm
Thanks for the advice. To check for voltage do I just put my back cable from the multimeter on the blue wire and the red cable on the brown wires and set the meter to 250v to see if I get a reading ?
Thinking back I did allow the light to hang for a few seconds becaus the wife closed the kitchen window snd i wss boilkng, which could of been enough for a wire to work loose. Is it likely this flex cable(brown, blue, yellow) connects to a junction box above the joist. What is confusing is I have a two way switch in the kitchen. One for the light that's working and one for the light that is not. When I checked the switch it has red and black cables in there not the flexy cable type colours. Is it likely then one set of the red and backs from the switch go to a junction box above ceiling and then a flexible is fed down to the light. If so this is making sense.
Does this mean to get to the junction box I need to rip up the carpet and floorboards in the bedroom above the kitchen to get to the box.
What a nightmare.
Thanks.
Col
PostPosted: Tue Aug 15, 2017 10:09 pm
Technically that's incorrect could be many factors or missing a live or neutral or switch is not wired in correctly in which case there could be 230v present
PostPosted: Tue Aug 15, 2017 10:23 pm
Has thanked: 42 times
Been thanked: 1266 times
Thanks.
Col
Not being "funny" but as electricity can kill anyone, if you have to ask how to use a multimeter, I suggest you get some one in to do the job for you. :cb
PostPosted: Tue Aug 15, 2017 10:36 pm
I will check it in the morning and report back. I know what to do now.
Still feel there will be no voltage and this flexy is connected to a junction box above the ceiling and the live and/or neutral has come loose.
For this message the author Goldcol76 has received gratitude : multiman
PostPosted: Wed Aug 16, 2017 8:26 am
Be careful with live testing always wear gloves a non contact pen is useful for tracing live wires
