It is currently Fri May 25, 2012 4:32 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 15 posts ]
 Post subject: New Laminate floor.
PostPosted: Thu Nov 10, 2011 9:25 pm
Has thanked: 1 times
ive had a new laminate floor put down in my hall way today. in places it is a bit springy! will this bed down? i used a fiberboard underlay, and the subfloor was pretty level.
 Post subject: Re: New Laminate floor.
PostPosted: Thu Nov 10, 2011 10:56 pm
Has thanked: 134 times
Been thanked: 472 times
is there a full 12mm expansion gap in all areas including under or to skirting door frame and joining strips
there must be nothing in the gaps
there should be no spring at all after fitting is it a bump or a hollow??
PostPosted: Thu Nov 10, 2011 11:08 pm
Has thanked: 17 times
Been thanked: 58 times
Following on from the questions above, how & where was the flooring stored for the 72 hours prior to fitting?
And are you missing a hamster?
If at first you don't succeed - remove all evidence that you tried.
PostPosted: Thu Nov 10, 2011 11:15 pm
Has thanked: 57 times
Been thanked: 99 times
:shock: :shock: :lol:
If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here
PostPosted: Fri Nov 11, 2011 11:58 am
yes expansion gap was left. it seems to be hollow in a few places? is this the norm? and no im not missing a hamster!! lol
PostPosted: Fri Nov 11, 2011 1:31 pm
have you got a strait edge like a long spirit level or bit off wood place this across the area to see if its a bump or dip
PostPosted: Fri Nov 11, 2011 3:02 pm
it only dips when you walk on it!! floor is level!
PostPosted: Fri Nov 11, 2011 3:21 pm
so you have a hollow??
if its a hollow you should have padded the area before instalation to make it level
how much does it drop and what underlay did you use ??
PostPosted: Fri Nov 11, 2011 5:15 pm
i used fibreboard underlay. it drops a couple of mm. will it bed down?
PostPosted: Fri Nov 11, 2011 5:30 pm
try placing a heavy enough load to hold it down against the spring for a couple off weeks but dont hold your breath :dunno:
PostPosted: Fri Nov 11, 2011 5:40 pm
thanks. i suppose im just going to have to live with it! its not too bad but i notice it!!
PostPosted: Fri Nov 11, 2011 7:01 pm
Has thanked: 166 times
Been thanked: 613 times
You'll find that over time the laminate will crack apart at the tongue..better to lift it (If possible) and re-lay on a sound level substrate...
PostPosted: Fri Nov 11, 2011 9:00 pm
its not really possible to lift! skirting is fitted on top!
PostPosted: Fri Nov 11, 2011 10:41 pm
options are to pad out by drilling small holes injecting liquid and pumping it around but not ideal
PostPosted: Sat Nov 12, 2011 9:58 am
think i will just leave it! its not bad, but i know its there!!! if u know what i mean!
