It is currently Fri May 25, 2012 4:20 am
PostPosted: Fri Jul 10, 2009 11:41 am
Hi Gang, just had some new sink and bath taps today, sink one is no problem as it came with two flexible pipes to reduce from 15 to 10mm. Bath taps just came on their own and are bigger threads than my 15mm pipe, I think they would be 22mm, so what do I need to connect these taps to my 15mm pipe. Thanks in advance for any help. :help: :scratch:
 Post subject:
PostPosted: Fri Jul 10, 2009 11:58 am
Has thanked: 51 times
Been thanked: 230 times
3/4 - 15mm tap connectors.
I always use the speedfit ones with the rubber seal in them. You don't need to tighten much more than hand tight. :wink:
Dave
www.drlgas.co.uk
 Post subject:
PostPosted: Fri Jul 10, 2009 1:07 pm
Thank Dave, are the speedfit type like those on my basin, flexible mesh type(sorry about the description), so I'll know what to get then. :thumbright: :sign7:
 Post subject:
PostPosted: Fri Jul 10, 2009 1:19 pm
OAP
Has thanked: 187 times
Been thanked: 2114 times
Yes they are the same with a flexible hose.
FLX 16 is 300mm long.
FLX 20 is 500mm long.
FLX 38 is 500mm long with service valves.
All the above are 15mm pipe to 3/4" taps.
Don't forget you need the inserts when using plastic pipe.
 Post subject:
PostPosted: Sat Jul 11, 2009 11:04 am
OK, that's cleared up all my problems, for now at least, so thanks to you both for your help. :-) :wink:
