Ultimate Handyman Home
need to know cost of a pumped shower supplied
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum
reefer
Junior Member
PostPosted: Fri Sep 19, 2008 6:34 pm    Post subject: need to know cost of a pumped shower supplied Add User to Ignore List Reply with quote
and fitted inc the electrical work ?
anybody give us an idea ?
cheers
Back to top
Steve the Gas
PostPosted: Fri Sep 19, 2008 6:43 pm    Post subject: Add User to Ignore List Reply with quote
Hello & welcome
But stay off the reefers Thumbright
How long is the proverbial?
If its easy, say £???
just jokin Thumbright
Soz peeps in denile Wink
Back to top
thescruff
PostPosted: Fri Sep 19, 2008 6:47 pm    Post subject: Add User to Ignore List Reply with quote
2k should cover it.
Scruff
Back to top
bathstyle
BATHROOM DESIGN AND INSTALLATION
PostPosted: Fri Sep 19, 2008 7:56 pm    Post subject: Add User to Ignore List Reply with quote
Let's take a look at the costs
Grohetherm 1000 Bar style shower valve with slider bar £150
1.5 bar Stauar Turner Showermate pump £150
Pipe, fittings, valves, flange, Tank Connector, insulation £200
Labour to install Pump + Valve (Could well be 2 days) £500
Labour and Materials to install fused switch for pump £90
£1090
+ VAT
Back to top
reefer
Junior Member
PostPosted: Fri Sep 19, 2008 9:30 pm    Post subject: Add User to Ignore List Reply with quote
was a bit impatient soz, i should have given more info
Its a tenement flat someone below her and someone above her theres only low pressure in bathroom so mum wants same shower as mine, the council installed mine.
Its a triton t80si 9.5 kw pumped that she wants, electric cable will need to be approx 12 metres and about the same in trunking. The cable and trunking will have to go on the wall 6 inches from ceiling as my mum has laminate flooring down evereywhere.
ps
bathstyle thats a bit out her range pal, i take it that is a top notch one
Back to top
bathstyle
PostPosted: Fri Sep 19, 2008 10:07 pm    Post subject: Add User to Ignore List Reply with quote
No, just a basic valve and pump.
What you're asking for is totally different though.
This is probably one for the Sparky Forum, at a guess just for the electrics would be about £250, It would require a 10mm cable all the way to the Consumer Unit, Unit may need upgrading or even a separate board.
Gotta be another £250 for the Plumber, then add on the materials and VAT.
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum All times are GMT
Page 1 of 1
