It is currently Mon Jun 25, 2018 8:46 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Aug 24, 2017 6:56 pm
Has thanked: 1446 times
Been thanked: 3700 times
I think that "only me" wanted a pic of the whole CU, I assume he wants to check whether your sockets are on a ring or radial circuit...
If radial then the socket with one cable could be the last socket on the radial.
PostPosted: Thu Aug 24, 2017 7:31 pm
Has thanked: 21 times
Been thanked: 12 times
How many cables at the other working socket, the MCB rating and the cable size?[/quote]
Its 40A MCB.
I took photo of cable size with socket loose , attached.
It's hard to take of the other socket of the wall who ever has done before is v stupid, I need to change it one day soon which another headache, what tools do I need to remove that socket from the wall gentle enough not break the tiles? Photo attached.
cheers
PostPosted: Thu Aug 24, 2017 7:58 pm
Has thanked: 42 times
Been thanked: 1274 times
That cable looks like its older than me :shock:
The problem is that with age it starts to break down, often its fine.............if you dont touch it.
PostPosted: Thu Aug 24, 2017 8:36 pm
Yes its fine, nothing is breaking.
PostPosted: Thu Aug 24, 2017 8:37 pm
...........but you moved it. With that stuff is also what you can't see. I wouldn't be happy if I had that stuff. But then that's me.
PostPosted: Thu Aug 24, 2017 8:47 pm
What are you talking about? What has moved!
PostPosted: Thu Aug 24, 2017 9:19 pm
Has thanked: 1055 times
Been thanked: 984 times
Mate, that stuff looks like old rubber insulated cable. It can look OK where you can see it, but the rubber insulation and sheath breaks down over time. If you physically move the cable it can crumble.
I'll guess that must be at least 50 years old! If your house is wired with that it all needs changing ASAP.
PostPosted: Thu Aug 24, 2017 9:23 pm
Has thanked: 696 times
Been thanked: 28 times
Get an electrician in firstly 40a is wrong for sockets also the insulation breaks down and you need to carry out insulation resistance tests before doing any work not just add fcu
PostPosted: Thu Aug 24, 2017 9:28 pm
Trouble is I've done insulation tests on the stuff and a lot of the time it reads OK.
When you pull it out it disintegrates.
We were pulling loads of the stuff out 30-40 years ago, advice was always to replace where it was found.
Part of the problem is that "cheap" "rewires" were being done in the 60s-70s, and all that was done was change the fittings. I came across several like that 30 years ago.
ETA I agree about getting an electrician in to it.
For this message the author Dave54 has received gratitude : multiman
PostPosted: Thu Aug 24, 2017 9:29 pm
Trouble is I've insulation tests on the stuff and a lot of the time it reads OK.
Agreed
PostPosted: Thu Aug 24, 2017 10:00 pm
I know you lots where you are coming from. I have seen wires breaking and crumbling. The insulation on these wires are in good state. You are going with what you have learned and regulations. Wire state depends on usage, the elements and heat generated plus age. I was told exactly the same by people just like you in 2002 when I bought the house. The house was partly rewired.
You know some of the regulations are OTT. Example, you could have a spur from a spur if they both are single sockets and that was the regulation for 100 years. But new regulation says you can only have one spur no matter if it's single or double.
Do you know how many properties in UK which have the original wiring! Zillions. They even have the old fuses without consumer unit, MCBs or RCDs.
Electricity is dangerous, best to be safe and no risks.
For this message the author yartin has received gratitude : multiman
PostPosted: Fri Aug 25, 2017 6:48 pm
Approved Electrician
Has thanked: 162 times
Been thanked: 562 times
You should have had a full rewire not a partial one.
A 40A circuit feeding sockets using VIR with no RCD protection - that's not a circuit I would work on.
For this message the author OnlyMe has received gratitude : Dave54
PostPosted: Sat Aug 26, 2017 4:47 pm
Very straight forward, if one cable then radial and put 20A, if 2 wire then ring 32A.
PostPosted: Sat Aug 26, 2017 5:12 pm
Has thanked: 11 times
Been thanked: 56 times
It's probably the old high level cooker point and someone has put a socket on in it's place.
For this message the author Morbius has received gratitude : multiman
PostPosted: Fri Dec 15, 2017 2:21 pm
All done, did a neat trunking, working all fine, cheers.
