It is currently Tue Oct 23, 2018 5:19 pm
PostPosted: Wed Oct 25, 2017 9:54 pm
Been thanked: 1 times
I bought a new curtain pole for my bay window only to find out the fittings are larger than the batten above the window. I'm not sure if this is normal as I've only ever had a cheap curtain track fitted to the batten. I have plasterboard walls but I'm not sure if it could hold up the weight or not. It's a 28mm metal pole with a rough length when fitted of 2.5m. Any advice guys?
PostPosted: Wed Oct 25, 2017 10:05 pm
Has thanked: 696 times
Been thanked: 28 times
Is there no brick behind plaster board you could alternativly use anchor plugs. Normally in this situation I use long drill bit and drill into brick wall then using long screw and plug on top tap in gently with hammer and tighten up or you could using fixing screws and plugs those have extra long plugs.
PostPosted: Thu Oct 26, 2017 10:34 am
Thanks for the info. I'll look into the options.
Everywhere else in the house is hollow between plasterboard and the walls. Above the window does sound a little more solid though so I am hoping it's at least brick.
For this message the author purpleishblue has received gratitude : multiman
PostPosted: Fri Nov 10, 2017 7:39 am
This makes me wonder if there's any brick behind plaster board you could alternativly use anchor plugs. Normally, I use and always prefer spam removed Mod 2.curtains to the rest and thank goodness, I've never encountered such mayhem.There are a variety of poles and other provisions that come with the set thus catering for any such inconvenience. However, I think that in this situation it's advisable to use long drill bit and drill into brick wall than using long screw and plug on top tap in gently with hammer and tighten up or you could using fixing screws and plugs those have extra long plugs. Hope that one works.
Cheers!
PostPosted: Sat Nov 18, 2017 11:05 pm
Has thanked: 147 times
Been thanked: 213 times
Do you actually NEED the full length. It might be easier to trim it so it fits to the (presumably securely fixed) batten. The tubular curtain poles are easily cut with a pipe cutter. Otherwise some masking tape and a hacksaw!
