It is currently Mon Oct 22, 2018 8:57 am
PostPosted: Tue Oct 10, 2017 12:34 pm
Hi
I have a Myson 800 Kickspace plinth heater. The fan continues to run even when the central heating is off and the water is cold. I assume this is because the low limit thermostat (part no. 1260007) is not working.
Could there be any other reason?
If not, how do I fit a new thermostat?
Cheers
PostPosted: Tue Oct 10, 2017 2:25 pm
Has thanked: 64 times
Been thanked: 543 times
It seems likely you are correct, it should switch at 35 degrees, but Myson do have various models so can't be 100% sure.
PostPosted: Tue Oct 10, 2017 9:39 pm
Approved Electrician
Has thanked: 166 times
Been thanked: 581 times
:welcomeuhm:
The electrical connections on Myson parts come with just simple spade terminals on them. So it a pull off push on job for the electrical work.
I have fitted a few remote stats but never replaced a low level stat. I assume that it just clips to a pipe and goes closed circuit when it reaches a certain temperature. The low level stat is left in place when fitting the remote stats
Disconnecting the stat by removing one of the blue wires to the summer/winter switch should prove that it is the stat at fault as this will stop the fan blowing when the heating is off.
PostPosted: Tue Oct 10, 2017 10:52 pm
Thank you for your help, problem now solved. Myson's counter intuitive switch settings (winter & summer symbols on the switch don't look like the usual ones) led me to have it on summer setting instead of winter! Driver error!
PostPosted: Wed Oct 11, 2017 2:50 pm
Has thanked: 27 times
Been thanked: 96 times
Yup that get me every time! Trouble is often or not the broom or Vacuum cleaner thinks it is great fun to switch it over!
