It is currently Fri May 25, 2012 3:53 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 26 posts ]  Go to page 1, 2  Next
PostPosted: Thu Nov 17, 2011 6:23 pm
Has thanked: 110 times
Been thanked: 1 times
Hello handyguys! My faucet's handle started leaking a few days ago and i affraid it will leak more. I have video'ed the situation for you to make it easier:
I am a beginner in home DIY but in my army service i was APC mechanic working with GMC's diesel motors so i have a little experience. Although it is said that this faucet is special and requires experienced person to fix. Personally i do not know what so special about it. A common faucet to me which probably has rubber misplaced under the handle which is causing leakage.
What do you think guys? Should i attempt?
I'm n00bie in DIY
PostPosted: Thu Nov 17, 2011 6:26 pm
Has thanked: 125 times
Been thanked: 392 times
Can't see the full tap, but it is probably just an O ring that needs replacing.
Have a look at this and it should give you some idea :wink:
http://www.ultimatehandyman.co.uk/taps/ ... er_tap.htm
DIY | Donnas dream house
For this message the author ultimatehandyman has received gratitude : Boris_yo
PostPosted: Thu Nov 17, 2011 6:58 pm
Thanks Admin. What i really hate about this tap is that you cannot control the exact flow of water you want when lifting/lowering by "hitting" the tap's handle. It is either medium or high, however if you grab the handle with all your soapy hand and gently pull, then you might get close.
I'm n00bie in DIY
PostPosted: Thu Nov 17, 2011 7:02 pm
Has thanked: 34 times
Been thanked: 182 times
haven't had a soapy hand pull in ages :lol:
Measure twice, cut once!
For this message the author Simon Site Manager has received gratitude : Boris_yo
PostPosted: Thu Nov 17, 2011 7:05 pm
That was a nice one! :mrgreen:
I'm n00bie in DIY
PostPosted: Thu Nov 17, 2011 7:13 pm
Has thanked: 166 times
Been thanked: 613 times
Boris
UHM is right, That'll be an O ring, your main problem will be sourcing the right size of ring..
PostPosted: Thu Nov 17, 2011 7:19 pm
I'm always sourcing the right sized ring :lol:
PostPosted: Thu Nov 17, 2011 7:23 pm
Troll Headbutter
Has thanked: 77 times
Been thanked: 130 times
Do you quite often find you have blown an o ring?
You need to use more lubrication and work objects in slowly. It can be terribly inconvineient if you just ram things in and tear it!
I had a quick look on the internet and found that hot towels can often help to soften things up - might be worth a try! Oh, it also suggests a bucket when working with o-rings - last thing you want is a mess all over the palce.
Cheers,
BG
PostPosted: Thu Nov 17, 2011 7:31 pm
What do i do with hot towels? Tie a handle with them?
I'm n00bie in DIY
PostPosted: Thu Nov 17, 2011 7:34 pm
Troll Headbutter
Yes, use them on the shaft for better grip
Cheers
BG
PostPosted: Thu Nov 17, 2011 7:40 pm
Don't grip too tight or use a serrated tool, you'll take the chrome off!!!!!
PostPosted: Thu Nov 17, 2011 7:52 pm
Cheers
BG
Actually the handle moves normally and i do not need to force it. Don't get what to soften with hot towel. The "O" ring so it settles on its place? :dunno:
I'm n00bie in DIY
PostPosted: Thu Nov 17, 2011 9:42 pm
Jack Of All Trades
Has thanked: 27 times
Been thanked: 55 times
Seems like you've led a sheltered life Simes!... :lol:
By eck! ©
PostPosted: Thu Nov 17, 2011 9:51 pm
Has thanked: 45 times
Been thanked: 124 times
can't be that serious if you had time to add music to the video before you posted it :lol: :lol:
Mike
http://rebuildingatimberbungalow.blogspot.com/
any advice welcome
PostPosted: Thu Nov 17, 2011 10:22 pm
Jack Of All Trades
The mournful music adds to the effect that the tap is crying!.. :lol:
By eck! ©
