It is currently Fri May 25, 2012 3:35 am
PostPosted: Sun Dec 11, 2011 10:37 pm
Has thanked: 33 times
Been thanked: 42 times
A pal needs a 8 or 10 pole plug and socket for his model railway layout, so that he con split the base board into two with quick connections between the tracks. Can anyone suggest a source of these low voltage units. Size doesn't mattter at the joint will be hidden.
PostPosted: Sun Dec 11, 2011 11:53 pm
Has thanked: 62 times
Been thanked: 217 times
He needs to use 'molex' connectors. These can be had in many different 'ways' and you buy the relevant parts as you need them (modular)
try here as an example:
http://uk.farnell.com/jsp/search/result ... rect=false
This post may contain nuts
PostPosted: Mon Dec 12, 2011 10:27 am
Thanks, I'll have a look at those.
