It is currently Thu Jan 17, 2019 3:00 am
 Post subject: MR16 to LED
PostPosted: Sun Jan 14, 2018 1:53 pm
Has thanked: 27 times
Afternoon all
I have 6 x 12v downlighters in my bathroom - each runs off its own transformer (60W) - can I replace the 12v MR16 with the equivalent LED's without having to change the transformers?
Cheers
 Post subject: Re: MR16 to LED
PostPosted: Sun Jan 14, 2018 2:17 pm
Has thanked: 39 times
Been thanked: 1405 times
No. :sad:
As you said, you have transformers, LED lamps do not like / run on Transformers. Also Some "transformers" have a minimum load requirement before they will switch on / work. You need to have "drivers"
That said you could buy 1 small powersupply and run them all from that. (Often these cost less than a LED driver) Only problem is they might not fit through the hole, but if you have access to above.............
Something like This Other suppliers of power supplies are available
For this message the author someone-else has received gratitude : marko65
PostPosted: Sun Jan 14, 2018 5:16 pm
OK Thanks - I could access from above as they go through to loft space - however that requires a lot of moving of insulation so may give that a miss and try and change everything through the hole.
Is this incorrect ?
https://www.lightbulbs-direct.com/artic ... with-leds/
PostPosted: Sun Jan 14, 2018 6:18 pm
Has thanked: 16 times
Been thanked: 97 times
I have a 4 lamp track light in my kitchen that takes 20w mr16 halogen lamps and I changed 3 for LED as they was on offer, the light instructions say the transformer needs 20w minimum to work so I left 1 halogen in it.
Many months later that eventually blew and the 3 LED's stayed on so I changed it for an LED and it is fine, I suppose it depends on the transformer fitted. :dunno:
For this message the author adonis has received gratitude : marko65
PostPosted: Sun Jan 14, 2018 6:19 pm
Not sure what you mean by "is this correct?" The link works and goes to a supplier, I will be honest, I didn't read it, If its a technical question about what they supply ask them.
Something I forgot to mention. :oops: Any powersupply you choose must be the same voltage as the lamps and a higher rated output than the total wattage of the new lamps.
So if you have 4 x 5 watt lamps, a 15w powersupply is too small and a 30w powersupply is fine (Since it is bigger than required)
PostPosted: Sun Jan 14, 2018 6:46 pm
Has thanked: 65 times
Been thanked: 546 times
There is no problem simply swapping quartz MR16 12 volt lamps powered by a transformer for replacement LED lamps, normally they are marked 50 Hz on the lamps to show they are designed to run from a transformer.
However are you sure they are powered by transformers? In the main people use electronic transformers these are not transformers they are completely different.
It is like trying to compare a car with a rail car, both have the name car, but they are nothing like each other.
I have 4 x 12 volt G5.3 LED lamps which have replaced the 4 quartz lamps running from a toroidal lighting transformer like this one Image and they have been in now for nearly two years with no problems.
It is possible these will also work should not really use then as output in kHz range, but where it said 0 - 50W likely they will work, but ones stating 20 - 60W likely will not work as under loaded.
But question as asked the answer is YES they will work as a direct replacement when powered from a transformer.
For this message the author ericmark has received gratitude : marko65
PostPosted: Sun Jan 14, 2018 8:19 pm
Ok -I've located the box for the transformer - it's a Dais DA-E60 electronic transformer 20-60W/VA
Can I remove the transformers and convert the fitting using these?
https://www.screwfix.com/p/luceco-gu10- ... 90mm/3751h
PostPosted: Sun Jan 14, 2018 9:02 pm
Is this incorrect ?
No it is not correct. There are many MR16 replacements, most are AC/DC and use diodes to ensure correct polarity and a resistor to limit current and will work on nearly any regulated 12 volt supply.
There are however specials which use pulse width modulated technology and are designed for a smooth DC supply often with a supply voltage range of 10 ~ 30 volt. They are designed for cars, caravans and boats i.e. from a battery, and not for use with the rough power supplies used with the fixed 12 volt bulbs.
In the main the problem is not the bulb but the power supply, and the lighting industry seems to have set out to confuse people.
So we have.
1) toroidal lighting transformer gives out around 12 volt.
2) Electronic transformer really a switch mode power supply often in kHz range and also often a minimum output as well as max.
3) The driver, tradition current regulated not voltage and DC, however there are some voltage regulated devices also called drivers, so in real terms driver means DC power supply and you need to read the label.
4) Battery although rated 12 volt they are often charged with a 14.8 volt supply, so you need a special lamp able to take the variable voltage.
PostPosted: Sun Jan 14, 2018 9:04 pm
Yes but it does require an earth so you may need new cables as well.
