Page 1 of 1
[ 12 posts ] |
| Author |
Message |
Walchy01
Posted: Wed Dec 28, 2011 9:09 pm |
| Senior Member |
Joined: Sun Dec 11, 2011 2:36 pm Posts: 140 Has thanked: 24 times Been thanked: 1 times
Hi there
I am wanting to move the stop tap in my front garden as i am about to have an extension that will cover it, what sort of money am i looking at to move it approx 3 metres from its current location?
| Top |
kintangoman
Posted: Wed Dec 28, 2011 10:11 pm |
| Senior Member |
Joined: Wed May 27, 2009 7:50 pm Posts: 774 Has thanked: 29 times Been thanked: 11 times
it depends on your location. different areas charge diferent prices
_________________ Men will always be kids. Even after they have grown up, they keep trying to go back where they originally came from!
| Top |
register or
log in
moggridgeplumbing
Posted: Thu Dec 29, 2011 8:59 am |
| Senior Member |
Joined: Wed Mar 23, 2011 6:54 pm Posts: 388 Location: South London & Surrey Has thanked: 4 times Been thanked: 39 times
Best to get a few quotes in.  too many variables (time and materials).
| Top |
register or
log in
Walchy01
Posted: Thu Dec 29, 2011 2:29 pm |
| Senior Member |
ok thanks guys for your advice, much appreciated.
| Top |
register or
log in
Walchy01
Posted: Thu Dec 29, 2011 3:29 pm |
| Senior Member |
Advised i can do this myself as it's on my land, any tips to a newbie? Thanks
| Top |
register or
log in
darrenba
Posted: Thu Dec 29, 2011 3:41 pm |
| Senior Member |
Joined: Fri Feb 01, 2008 11:02 am Posts: 1399 Location: Dorset Has thanked: 11 times Been thanked: 116 times
Yeah - be prepared to get very wet You need to dig down first and find out what the pipe is made of. If it's plastic then you'll be able to clamp it shut a bit, if it's lead then check with your water supplier as they may do it for free, if it's steel then you're going to get very very wet doing it live.
| Top |
register or
log in
register or
log in
Walchy01
Posted: Sat Dec 31, 2011 2:51 pm |
| Senior Member |
Thanks Guys, a little problem today I lifted the steel stop tap cover and gave it a wiggle and hey its loose in my hand I then dig down thinking it must be down here somewhere, but nope it wasnt... so i went under the house and i can see the old lead pipe that has been cut at some point from what i would presume used to connect to the said stop tap that i cannot find... then i noticed a blue pipe coming in from 2 foot away that looks like a newish water pipe...
Could this be that the old lead pipe has been cut off along with the stop tap?
I do have a stop tap at the top of my drive on the foot path, is this now what you would expect to be my "new" stop tap???
I also have a stop tap in my kitchen, i take it that as long as i have access to both of these i will be able to turn my water off
My worry is that there is another one somewhere else near my front door and shortly my extension will be built and i obviously do not want to build over any stop tap, well thats my concern anyway
| Top |
register or
log in
darrenba
Posted: Sat Dec 31, 2011 3:01 pm |
| Senior Member |
I reckon that the one at the top of your drive would be the new one - lift the cover, turn it off and see. It's certainly where I'd expect it to be.
| Top |
register or
log in
thescruff
Posted: Sat Dec 31, 2011 3:02 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39985 Has thanked: 187 times Been thanked: 2114 times
Sounds like the old lead has been replaced.
Why not turn the stoptaps off and check they are ok.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
register or
log in
northwales4u
Posted: Tue Jan 03, 2012 5:07 pm |
| Senior Member |
Joined: Sun Jul 25, 2010 5:32 pm Posts: 2181 Location: Wrexham, Wales Has thanked: 45 times Been thanked: 124 times
My bro-in-law did this a while back. My little project has a water meter that is within the boundary and (he used to be a plumber for Welsh Water) just dug out by the water meter and replaced the whole pipe from their onwards for plastic - not sure about the situation if the meter/mains stop tap is in the road
| Top |
register or
log in
Page 1 of 1
[ 12 posts ] |
