It is currently Fri Jan 19, 2018 1:48 pm
Visit Thermo worx
PostPosted: Sun Nov 08, 2009 7:44 pm
I am installing a cooker hood. The current electical connection needs to be moved over a few cm's so it is behind the cooker hood chimney. The connection is a metal plate.
Can I just move the connection over (assuming there is enough wire), fit the new connection and fill in the hole left by the old connection?
If not any suggestions on the best way to do this
 Post subject:
PostPosted: Mon Nov 09, 2009 12:15 am
Pro Tradesman
Has thanked: 199 times
Been thanked: 330 times
personally i refuse to do that. it put an isolator out of reach. also it adds grease to the connections over time and damages the switch.
when customers want this out of site i site the switch elsewhere but accessible and then use a flex outlet plate inside the hood.
 Post subject:
PostPosted: Mon Nov 09, 2009 8:59 am
Thanks for the reply. Its not the cooker switch I want to move that is switch is accessable. All I want to move is the connection that will power the hood.
Is that still something you would not do?
 Post subject:
PostPosted: Mon Nov 09, 2009 11:17 am
Has thanked: 422 times
Been thanked: 3902 times
Sort of a junction box behind the hood.
Will you still be able to get to it, after the chimney is installed.
