It is currently Fri May 25, 2012 2:26 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Wed Nov 30, 2011 6:25 pm
Has thanked: 43 times
Been thanked: 43 times
Mainly for thescruff but any contribution welcome as I have just seen a comment in another question.
Mixer tap with hot gravity fed and cold from the mains. Do I need a check valve on the cold for meeting regs?
If I also fit a check valve on the hot (in the hope of managing to achieve mixing of the two supplies) will it help at all or simply hinder the supply of hot water?
TIA
Och Aye
PostPosted: Wed Nov 30, 2011 6:41 pm
OAP
Has thanked: 187 times
Been thanked: 2114 times
Yes you should.
Check valves are used to prevent backflow when the pressure are unequal, and more importantly when/if the mains is turned off, or interrupted to prevent contamination.
