It is currently Fri May 25, 2012 2:21 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 19 posts ]  Go to page 1, 2  Next
PostPosted: Tue Nov 29, 2011 4:48 pm
Troll Headbutter
Has thanked: 77 times
Been thanked: 130 times
Ladies, Gentlemen and fellow goats....
Just doing a trail run install of the shower before I get my bush board up (fnarrr fnarr) on the walls and wondered what was 'normal' for a mixer shower in terms of the tails sticking out.
It feels alright on the wall with little movement and I've not even used the lock nuts (saying that, I can only get one side on.....this is NOT a stud wall with rear access), I just wonder if this looks OK.
Ignore PTFE, it was used for some cap nuts while I was checking for leaks....couldn't be bothered to take it off.
Behold....
Thoughts?
BG
PostPosted: Tue Nov 29, 2011 6:38 pm
Has thanked: 57 times
Been thanked: 99 times
Looking good
Should be ok as long as panel not thicker than the threads showing ( with ptfe tape on),as that is the space you will have to play with
is shower up side down?,is so and fitting that way for,say rigid riser make sure hot and cool right way round
If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here
PostPosted: Tue Nov 29, 2011 6:39 pm
Has thanked: 51 times
Been thanked: 230 times
I hate stating the obvious, but it is upside down, is it not?
Other than that looks fine to me :thumbright:
Dave
www.drlgas.co.uk
PostPosted: Tue Nov 29, 2011 7:01 pm
Troll Headbutter
Thanks for the input chaps, appriciate it!
It's 100% the right way round, the top hole you can see if for the rigid riser and there is another underneith for the hose attachement thing. Got the hot and cold the right way round too, there are red and blue spots on the back and I've marked my pipes the same colours.
Was worried it needed cutting down, but mocked up some board the same thickness as whats going up.....I must admit, i'm quite excited! Scared of cutting the board though for the holes.....it's bloody expensive stuff!
BG
For this message the author BillyGoat has received gratitude : white pan man
PostPosted: Tue Nov 29, 2011 7:05 pm
Has thanked: 166 times
Been thanked: 613 times
BillyGoat wrote:
Thoughts?
BG
I just love the way you've gone all "Arty" with the contrast of colour and Black & White in the pics...
Nothing useful to add though.
PostPosted: Tue Nov 29, 2011 7:23 pm
Troll Headbutter
Both are colour :lol:
I'm using my crappy camera, just lucky I guess! It was the best of TEN pictures!
PostPosted: Tue Nov 29, 2011 9:29 pm
Troll Headbutter
Errr....so, I'm a doosh. Missis watching TV so I went to carry on getting things ready for the shower - turns out it WAS upside down. :?
Pipes still alright though....so there. :B
PostPosted: Tue Nov 29, 2011 9:30 pm
OAP
Has thanked: 187 times
Been thanked: 2114 times
We know :mrgreen:
PostPosted: Thu Dec 01, 2011 12:53 pm
Troll Headbutter
Two other questions regarding my shower install. Don't want to cock it up and have to pull the boards off the wall (full bathroom pictures when I've done the shower to go into my project!)
There is a place on the threads to hold when tightening the shower nuts.....any ideas of a tool that can fit in such a small space? All my grips and pliers are all too wide...You can see the cap above and the thread looks like this:
Also, there are these bits that go in the valves....are these needed? I saw a bried mention of flow restrictors. I know the strainers are required (even though it looks like there are some built in), what about the rest? The book just gives an exploded view with no detail.....don't want to put extra stuff in that will reduce the flow with no added benefit!
PostPosted: Thu Dec 01, 2011 1:00 pm
Has thanked: 17 times
Been thanked: 265 times
As I understand it the flow restrictor is to allow a balancing of hot and cold to get the mix right. If the cold dominates the flow then the restrictor would help achieve balance.
So what is the mains pressure like and is this running off a combi?
PostPosted: Thu Dec 01, 2011 1:09 pm
Troll Headbutter
Ahh, I'll leave the restrictors out then!
Can achieve around 19lpm here at the busy times of the day....not too bad considering I've got a lead supply. I'm at the bottom of a massive hill though. Boiler is indeed a combi, Baxi Platinum 33HE
(Edit: I know we arn't going to have a 'power shower' experience, but it's going to be better than the electric shower I've been living with for god knows how long!)
BG
PostPosted: Thu Dec 01, 2011 1:15 pm
OAP
I would use the restrictor rings, would have thought there would be a washer where you show.
Thin adjustable or the right size spanner.
PostPosted: Thu Dec 01, 2011 2:58 pm
Troll Headbutter
Top notch...I'll treat myself to somthing that'll fit. It's almost like I need one of those bike spanners you used to get years back with the multiple holes - that kindof thin.
I'll try with the restrictors in.....makes it look like no water would get in! :shock:
PostPosted: Thu Dec 01, 2011 4:20 pm
OAP
You may find you'll need the restrictor for the cold and not the hot. follow the mi
PostPosted: Thu Dec 01, 2011 4:41 pm
Has thanked: 76 times
Been thanked: 373 times
For a 33kW combi I wouldn't fit any restrictors personally the valve will be able to cope with a certain amount of imbalance anyway :wink:
And it shouldn't be all that far off a powershower albeit not in the same league as some of the swanky hotels you frequent :lol:
cron
