It is currently Fri May 25, 2012 2:14 am
 Post subject: Mini-Trip MCB type
PostPosted: Thu May 07, 2009 2:36 pm
Sorry if this is a dumb question but I bought a 5A Mini-Trip MCB Type B unit this morning from Wickes to fit into my existing fuse-box for the downstairs lighting circuit. Problem is, it doesn't fit as the two "pins" are too wide apart for the socket.
I've obviously bought the wrong type so what should I be looking for ?
Any help appreciated !
 Post subject:
PostPosted: Thu May 07, 2009 3:13 pm
Try here
http://www.thefusecompany.com/fuse.php? ... cts_id=413
Have you changed the housing from the rewirable to the mcb type?
 Post subject:
PostPosted: Thu May 07, 2009 3:42 pm
Errrrrr ...... nope !
That must be the dumb mistake I've made. How easy is it to change the "housing" and is that the "base unit" referred to on the link you provided ?
 Post subject:
PostPosted: Sun May 10, 2009 9:48 am
Has thanked: 2 times
Been thanked: 99 times
If its a wylex board then simply turn the main switch off, remove the fuse and if you look at the carrier in the fuse box itself there is a small slotted screw, undo this and the carrier bit comes out, then replace this with the new one supplied with the mini trip , plug in new mini trip and re energise the fuse box.
Nick
