It is currently Fri May 25, 2012 2:07 am
PostPosted: Tue May 10, 2011 5:30 am
Has thanked: 5 times
hi everybody,
I was just wondering if somebody can provide me technical help. I'd like to know which method and tools can I use to cut aluminium alloy plate? Thickness is 8mm.
Regards
PostPosted: Tue May 10, 2011 6:18 am
UHM Super Moderator
Has thanked: 24 times
Been thanked: 63 times
Hi Alogoz :welcomeuhm:
I've moved your question to the metalworking forum where you're a bit more likely to get an answer :wink:
Moderator 6
For this message the author moderator6 has received gratitude : Alagoz
PostPosted: Tue May 10, 2011 8:09 am
Has thanked: 134 times
Been thanked: 472 times
sounds very industrial to me
what size off sheet [w x length]
jigsaw with metal blade comes to mind
For this message the author big-all has received gratitude : Alagoz
PostPosted: Tue May 10, 2011 10:51 am
OAP
Has thanked: 187 times
Been thanked: 2114 times
Hacksaw, bandsaw, and heat cutting equipment, Press.
For this message the author thescruff has received gratitude : Alagoz
PostPosted: Tue May 10, 2011 5:38 pm
Has thanked: 62 times
Been thanked: 217 times
Jigsaw and/or a rip saw will work. You need quite coarse teeth on the cutting blade and a medium speed. I used to watch guys in an aluminium fabrication place cut all sorts of plate, pipe, angle etc using a chop saw. Just watch out for the HOT shards!
I've also cut 10mm plate using a jigsaw and a WOOD cutting blade - I made a 250mm diameter disk out of 10mm thick square plate. Rather easy I thought.
This post may contain nuts
For this message the author kellys_eye has received gratitude : Alagoz
PostPosted: Tue May 10, 2011 6:33 pm
Has thanked: 6 times
Been thanked: 108 times
Circular saw, with a fine negative rake blade.
Jigsaw will do it, but much slower than the circular saw.
If you have a lot to cut, might be worth buying a metal cutting circular saw.
For this message the author Hitch has received gratitude : Alagoz
PostPosted: Tue May 10, 2011 8:37 pm
Thanks very much everybody.
I was thinking to use a Jigsaw with metal cutting blade of 14 TPI. The size of the plate is 25 x 40cm
PostPosted: Tue May 10, 2011 9:20 pm
assuming you have curves and its a one off then a metal blade is your best bet as its a £2 outlay
