It is currently Sat Mar 23, 2019 6:53 am
 Post subject: Metal plug socket
PostPosted: Fri Dec 21, 2018 7:23 pm
Has thanked: 3 times
Hoping that someone can help, have recently moved house and looking at repacing the plastic plug sockets for metal ones. Will I need to use both earthing terminals on the plug, one to the backbox and one to electricals. Or can I just use one of the earthing terminals without connecting it to the backbox. The backbox is metal.
Thank you.
 Post subject: Re: Metal plug socket
PostPosted: Fri Dec 21, 2018 7:35 pm
Has thanked: 41 times
Been thanked: 1446 times
It is good practice to use both, put the main earth to the socket and a fly lead to the box.
PostPosted: Thu Dec 27, 2018 10:35 am
Thankyou for the reply, with the flylead can I wrap the neutral wire around one of the fixing screws for the backplate?
PostPosted: Thu Dec 27, 2018 12:39 pm
NO!
The Neutral goes to the N terminal on the back of the socket. The Live goes to the L terminal on the back of the socket
PostPosted: Thu Dec 27, 2018 1:42 pm
Thankyou, sorry dont think it was that clear lol, the neutral wire I am going to connect to the neutral terminal on the socket. The plug has two neutral slots so I was going to connect the second neutral slot to the back box, would it be ok to connect this to the backbox by putting it around the holding screw for the backbox.
Thank you
PostPosted: Thu Dec 27, 2018 1:53 pm
Why?
I already told you what to do
PostPosted: Thu Dec 27, 2018 3:34 pm
Old School Chippie
Has thanked: 791 times
Been thanked: 1576 times
If it's in a masonry wall your back box should have a screw connector like this one has at the bottom left:
Absolutely the only connection you should ever make to this is the EARTH - connecting the neutral could result in you electrocuting yourself. The switch plate may well have two N (neutral) openings in it, but it will almost certainly have a copper or brass strip connecting the two sockets, so there's only ever a need to connect one of them. You absolutely MUST connect the earth on the plate as well. It is often indicated by this symbol and the letter "E":
It is this EARTH on the switch plate which should have the small fly lead running from it to the earth connector in the back box. For completeness the exposed ends/fly lead of the earth should also be protected with a yellow/green PVC sheath. If your backbox is in a stud wall it may well be a plastic dry lining back box, like this one:
In which case there is no need to connect an earth to the back box as it is made from an insulating material. DO NOT wrap any wire around the fixing screws
PostPosted: Sat Dec 29, 2018 6:21 pm
Has thanked: 1535 times
Been thanked: 3869 times
Thank you
This shows a woeful lack of knowledge of domestic electrics.
I would strongly advise that you get someone in who is competent.
