It is currently Tue Apr 23, 2019 1:16 am
 Post subject: Metal or plastic
PostPosted: Tue Aug 28, 2018 12:04 pm
Has thanked: 5 times
Hi guys
I’m putting in power sockets in my shed and I want to know if there is any regulation to stop me from using plastic back boxes as opposed to metal.
I know the metal ones are harder to break If anything falls against them but no children will ever be in in the shed, or would you recommend fitting metal fittings and stop being a tight sod.
Thanks for your input and suggestions
Ronin
 Post subject: Re: Metal or plastic
PostPosted: Tue Aug 28, 2018 1:55 pm
Has thanked: 107 times
Been thanked: 308 times
Guess you are talking metal clad for face fitting (not recessed galvanised type). My garage has all plastic fitted by an electrician before I moved in, they seem to be ok but just as with consumer units metal preferred in my books. Don't know the regs waiting for experts to advise.
PostPosted: Tue Aug 28, 2018 4:29 pm
Has thanked: 8 times
Been thanked: 25 times
Metal sockets arent that expensive, I bought some for my shed but not had the them fitted yet: https://www.screwfix.com/p/13a-2-gang-s ... clad/69127
That price includes the socket plate and back box.
PostPosted: Tue Aug 28, 2018 6:18 pm
Thanks for the replies
I think I’ll go for the metal option as they will be better wearing.
PostPosted: Tue Aug 28, 2018 7:01 pm
Has thanked: 82 times
Been thanked: 192 times
Sensible decision but be aware that whereas plastic surface boxes are normally cabled through trunking (and there are in fact particular back boxes available for the job), metalclad sockets should be cabled through conduit. This requires a connector piece inserted into the knockouts in the box, and possibly elbows and tees for joining lengths, as well as saddle clips for wall fixing. But it will definitely look the part.
Conduit & components are available from:
CPCcouk (min. order for free shipping £6 inc. vat, if you order some 3m lengths your order will be delivered ND by UPS as they can't then use RM;
TLCDirect (carriage charge unless collect from a branch near you) online;
S/Fix (buy too much & take back what you don't use);
and of course all electrical wholesalers (at a higher price than the others mentioned, in my experience).
Comes in black or white, which is a bit odd as metalclad is usually grey.
PostPosted: Tue Aug 28, 2018 8:59 pm
Has thanked: 41 times
Been thanked: 1470 times
If the OP was to go down that route, the sockets should also be wired in singles not Twin and earth.
Just use twin and earth and do use grommets, preferably come in from the bottom of each socket. (Stops things falling in through the grommet hole)
PostPosted: Tue Aug 28, 2018 9:41 pm
A. As OnlyMe will concur, T&E in normal use gives two layers of insulation (the inner cores and the outer casing) whereas with single strand (the inner cores) the conduit provides the outer - there is NOTHING to prevent you, in a simples ring main installation, putting two T&E cables in a conduit (providing three layers of insulation and so ott). Single strand comes into its own with multiple circuits in the same conduit, industrial applications, and wishing to put 2.50mm power & 1.00mm lighting through the same piping. Much tidier.
B. What would be the point of using metalclad boxes if the T&E is clipped to the wall unprotected & entering through grommets. Such an installation would an untidy and unprofessional abortion, no impact resistance for the t&e. Humph. Ugh. Yuk. Puke.
As mentioned before, black (or white) conduit, clipped back properly, connectors, tees & elbows (glued, to be pedantic) and metalclad fittings will easily, and at low cost, provide a professional & industrial standard installation in what is, to be frank, a garden shed. At minimal cost, if you use cpc as an e.g., top class result for little effort.
As I have here.
PostPosted: Tue Aug 28, 2018 9:55 pm
But two 2.5 mm twin and earth cables in 20mm conduit does not allow enough "air space" since you are only supposed to use 40% of its capacity.
For what its worth, you can hit a clipped twin and earth cable with a hammer and it wont go bang.
You hit it with a sharp edge and yes it will go bang, that same sharp edge will also slice through plastic conduit.
Plastic conduit and trunking is more for aesthetics / cable management than mechanical protection.
PostPosted: Tue Aug 28, 2018 10:11 pm
Approved Electrician
Has thanked: 175 times
Been thanked: 594 times
I do concur.
For this message the author OnlyMe has received gratitude : arco_iris
PostPosted: Tue Aug 28, 2018 10:14 pm
I figured you would.
We will just have to agree to disagree
PostPosted: Wed Aug 29, 2018 4:51 pm
Air space is to allow for heat dissipation, correct? If the conduit is clipped to garage wall which will be cold, is loss of air space going to have much of an impact?
ah
PostPosted: Wed Aug 29, 2018 7:08 pm
There are two types of plastic for back boxes.
Moulded brittle plastic ones or PVC conduit ones.
The PVC conduit ones are as indestructible as the metal ones unless you use fire or really want to hit it with a sledge hammer.
Two 2.5mm T&E down a 20mm conduit. It's doable, but 25mm conduit would be better. Derate the cables by 20% and they are still within spec.
It's not much different to using oval plastic conduit to supply cables recessed sockets in the house.
