It is currently Thu May 24, 2012 11:46 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: megaflo immersion heater
PostPosted: Thu Dec 08, 2011 7:47 pm
hi there, new to these forums, great info
Quick question
I have been asked to wire an immerser on a megaflo, it was heated indirectly, which has now been removed, and the immerser was never connected.
They now want this connected, there is a isolater switch with 1 m of hr cable. Live and nutral will go to stat, there is no earth post, but there is a earth connection on immersion housing with a stud on the megaflo body, does the earth from the hr cable go to this stud ?
cheers
Andy
PostPosted: Tue Dec 13, 2011 8:01 am
No ??, Yes ??
Ta
PostPosted: Tue Dec 13, 2011 8:10 am
OAP
Has thanked: 187 times
Been thanked: 2114 times
Same answer as the other thread, you need to be competent to work on an unvented cylinder.
All the earth connections must be linked back to the main earth supply.
The instructions are in the manual, if you want to be reckless and put the occupants at risk, I suggest you read it first.
PostPosted: Tue Dec 13, 2011 8:41 am
I have allready contacted a spark. who will be here today
I was just want to make sure I was getting it done correct as i dont know the guy.
All i wanted was advice, which i got. I Acted on it
jeez
and its a different answer :wink:
PostPosted: Tue Dec 13, 2011 8:58 am
OAP
If the spark has the G3 then he should be competent to do the work and certify it safe
PostPosted: Thu Dec 15, 2011 10:32 pm
Has thanked: 9 times
Been thanked: 62 times
iv seen soo many unvented's piped and wired wrong im supprised more houses havnt blown up since
PostPosted: Fri Dec 16, 2011 3:56 pm
Thanks people
Spark came, drilled out old stud and renewed, and also pointed out that there was no PRV on the cold supply to megaflo, plumber has now fixed that too
Cheers
Users browsing this forum: No registered users and 9 guests
