It is currently Thu May 24, 2012 11:40 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
PostPosted: Mon Mar 21, 2011 10:57 am
Hi Knowledgeable people!
I've just boarded out a whole room with Thermaline 35mm insulated plasterboard and need to put some mechanical fixing into the boards as well.
Whats the best way of doing this? The boards are onto brick walls, where I tried in one spot to drill through with a masonry bit the drill jumped as it went from board into the wall and made the hole in the board too big for the screwhead to take.
This was with pushing a plug into the hole and then screwing through, would frame fixings / hammer fixings be better?
Any guidance as to what I should be doing / tips?
Thanks,
GM
PostPosted: Mon Mar 21, 2011 1:13 pm
Has thanked: 10 times
Been thanked: 28 times
These are possibly your best bet
PostPosted: Mon Mar 21, 2011 4:25 pm
Has thanked: 1 times
Been thanked: 12 times
have you tried knocking on the board and trying to find the dabs then drilling through them??
PostPosted: Mon Mar 21, 2011 4:30 pm
Has thanked: 5 times
Been thanked: 4 times
Drill with a masonary dril and then screws with a washer. works all the time
so put the plug on the screw, tap in and screw
PostPosted: Mon Mar 21, 2011 8:02 pm
Has thanked: 58 times
Been thanked: 272 times
Use a percussion drill and not and sds. Slower but it won't jump.
Or put on so much weight, like me, that the drill doesn't jump.
PostPosted: Tue Mar 22, 2011 10:18 am
Thanks for the tips guys, I thought about just using a washer but I was worried that it wouldn't plaster well if it didnt sit flush
Apart from being a bit pricey those drywall fixing amarg linked look pretty good, don't need many anyway so I've ordered some of them
PostPosted: Thu Mar 31, 2011 10:49 am
The mechanical fixings in the video there are the ONLY things to use, I have done thousands of these boards and any other method is ridiculous.
If you have dot and dabbed you only need say four per board for fire regulations.
Get the steel ones and not the plastic, steel cost more but the plastic ones bend and you only get one in every three to fix properly.
