It is currently Thu May 24, 2012 11:35 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Fri Jul 17, 2009 7:39 am
Seeking to find out the name of a particular material used in stud partition manufacture. partitions that come from kit builders have 4"x2" frame and OSB (or similar) of the side that faces the external brickwork. Normally on OSB there is a 'paper' like covering to act as moisture barrier, so I understand, from the OSB and brick. Can someone tell me the industry name for that 'paper' covering so I don't look like a real plonker going to a builders merchant asking same question.
thanks
Mark
 Post subject:
PostPosted: Fri Jul 17, 2009 1:59 pm
Has thanked: 11 times
Been thanked: 116 times
Sounds like a Vapour Barrier to me. Something like this - Vapour Barrier
Cheers,
Darren
Property Refurbishment & Maintenance Dorset
Users browsing this forum: No registered users and 6 guests
cron
