It is currently Thu May 24, 2012 11:35 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: MASSIVE BOILER PROBLEM
PostPosted: Fri Dec 09, 2011 8:50 am
Ok i have a baxi 105e combi im currently havin major problems with i get very mild hot water if im only using dhw to get hot water i have to turn ch on. If i do run dhw rads go boiling again no hot water. If the boiler is not being used the pressure gauge drops to zero when the ch is put on it repressurises over flow runs on every use
Help would be MEGA appreciated
PostPosted: Fri Dec 09, 2011 9:55 am
Has thanked: 57 times
Been thanked: 99 times
Sounds like,diverter valve requires repairing,expansion vessel re-priming ,new pressure release valve fitted and a good service given to the old bird ,give her a treat for christmas
If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here
PostPosted: Fri Dec 09, 2011 12:33 pm
Serious how much is all tha
PostPosted: Fri Dec 09, 2011 5:34 pm
Has thanked: 9 times
Been thanked: 62 times
the prv and expansion shouldnt be too bad its 30 mins work on a 105e unless your iso taps leak after
the diverter valve could be easy and be the diaphram but if the whole body needs changing it might get a tad expensive not astronomical though
PostPosted: Fri Dec 09, 2011 8:44 pm
Has thanked: 51 times
Been thanked: 230 times
Around £250 ish. Think yourself lucky you haven't the Alpha equivalent as you would be looking at around £300 just for the diverted valve.
Dave
www.drlgas.co.uk
PostPosted: Fri Dec 09, 2011 10:04 pm
ah alphas i have to contain my joy everytime i walk in to a house and see one of them
PostPosted: Sat Dec 10, 2011 10:29 am
Thanks guy ill think ill change the whole valve
Users browsing this forum: No registered users and 7 guests
