It is currently Thu May 24, 2012 10:04 pm
 Post subject: Mains Cable
PostPosted: Wed May 06, 2009 11:34 pm
Hi - I was wondering if anyone knows the diameter of the incoming 100 amp mains cable. I have a recommended 32mm duct in the ground which is paved over but I thing the duct may be creased as drain rods are tight to pull through. Electric company coming in a few days to lay new service and would like to know they will be able to pull through ok - Many Thanks.
 Post subject:
PostPosted: Thu May 07, 2009 12:41 am
Electrician
I don't think drain rods are the best thing for electrical service duct. Is the duct the proper one for main electric supply or did you use normal drainage duct?
 Post subject:
PostPosted: Thu May 07, 2009 1:00 am
OAP
Has thanked: 187 times
Been thanked: 2114 times
Did you put a draw string in and are the joints facing the right way
 Post subject: Mains cable
PostPosted: Fri May 15, 2009 11:30 pm
Thanks for replies - ended up digging up the flat spot as duct had gone down under weight of digger I suppose - anyways got a string through in the end and Murphys done a sterling job.
Now I have a new querry - I have wired smoke alarms in series ie feed from c unit to hall smoke and from hall smoke in three core to landing smoke on 6 amp mcb which I will change to 6 amp rcbo to bring it up to 17th. Also will change the rest of the 4 light circuits to rcbos leaving the power rings and cooker on split rcd. Is this right - Im now told its illegall for sparkies to do third party testing for self certify but bld reg drawings were passed on 16 edition. Ooh er !!!
 Post subject: Re: Mains cable
PostPosted: Mon May 18, 2009 10:06 am
Been thanked: 1 times
They won't work - you should have wired them in parallel.
Nothing has changed regarding Building Regulations certification rules with the introduction of the BS 7671:2008. It was always illegal for an electrician to lie about having done work which he did not do.
I'm sorry - I can't come in to work today, the voices are telling me to stay at home and clean the guns.
Users browsing this forum: OnlyMe and 7 guests
