It is currently Thu May 24, 2012 10:00 pm
PostPosted: Fri Nov 11, 2011 8:24 pm
Has thanked: 1 times
I've got 2 diamond warnings on a 60 van that have been on for a month+, pretty much detailed the van today (good clean) and noticed diamond rust patches under the magnetic stickers :wtf:
Is this to do with the magnets? or trapped water?
Taken them off till I can get sticky ones
Predictive text is for aunts
PostPosted: Fri Nov 11, 2011 9:33 pm
Has thanked: 31 times
Been thanked: 35 times
Under-label corrosion is a big problem in the petrochems industry and this sounds like a typical case. Trapped moisture/process temperature/atmospheric conditions provide an ideal platform for corrosion to occur.
It used to be very common to see flow direction labels and contents ID (located directly) on high-spec painted unlagged pipework but corrosion can occur which is out of sight under the label until the dreaded leak begins. Even stainless steel pipework can be affected by stress corrosion cracking (different mechanism but same outcome) if the label adhesive contains chloride.
http://www.isistherapytraining.com/
PostPosted: Sat Nov 12, 2011 6:21 pm
Thanks for the reply SW3
Something i've never thought about, but like you say it normally happens 'out of sight'
PostPosted: Sun Nov 13, 2011 6:35 pm
Has thanked: 15 times
Been thanked: 161 times
Always had the same problem, little rust marks appearing, solved it by having proper sign writing.
PostPosted: Wed Nov 16, 2011 4:28 pm
We only carry oxy/propane when needed, I might try wiping a film of silicone grease on the other side before sticking and see if I get the same problem :dunno:
If so i'll have to go the sticker route with maybe a red magnetic line through if no gas onboard!
