Hello and help to any fellow plumbers out there. I hoping that you may see someting that I've missed?
Just finished installing a complete bathroom. Customer is very happy with end result. However, The Bristain artisan bar shower (thermostatic) is only, at best, giving out luke warm water. The system is off a Combi (Ideal mini) The shower can accept between .5 to 5 bar. All other outlets give our hot water. (Allbeit the bath hot is a bit of a dribble)
The static pressure off the hot and cold from the basin (which is next to the shower) both read 2.25 bar.
The shower is piped the right way round. The body of the shower and left union nut does get hot.
When I run the cold bath tap, it does steal some cold from the shower and therefore allows some hot through.
I've ordered a new thermostat cartridge, but I've got this horrible feeling that even after changing it, It'll still be a luke warm shower. I have no obvious pipework to get on to to install a PRV. but in all honesty, it shouldn't require it, given the 2.25 bar and fed from a combi. Even Bristain say the shower can handle 5:1 ratio.
Any thoughts??
