Ultimate Handyman Home
Looped heating pipes in airing cupboard.
Goto page 1, 2  Next
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers
Bludall
PostPosted: Tue Aug 28, 2007 3:13 pm    Post subject: Looped heating pipes in airing cupboard. Add User to Ignore List Reply with quote
I'm in the process of removing an airing cupboard to give us more room in our bathroom. I've come to a halt because there's a loop of heating pipe that goes to floor level and back up into the roof. It's not connected to radiators in there it just loops. It has a cut off valve about a third of the way down on each pipe and another valve near the floor.
I want to know whether we can just turn everything off and take it back to the loft or whether there is a good reason for the pipe configuration, apart from heating the airing cupboard.
We have a combi boiler and we live in a bungalow if that aids an answer.
Thanks,
Louise
Back to top
View user's profile Send private message Yahoo Messenger
Jaeger_S2k
PostPosted: Tue Aug 28, 2007 4:52 pm    Post subject: Add User to Ignore List Reply with quote
Hi Louise,
A picture would be really useful.
I assume there was once a hot water tank in this cupboard?
When it goes to floor level, what does it do? Loop up or terminate? Where does it originate? Down from the roof/loft or up from the floor?
Are they no branches coming from it? It's just a single pipe with valves but no terminated/blank branches from it?
Personally I can't think of a reason for it other than heating the cupboard which would be nice for hot towels or lazy heating engineer not pulling it back :) , but I'd really prefer to see it to comment further.
Jaeger.
FSBF
Back to top
Bludall
PostPosted: Tue Aug 28, 2007 4:58 pm    Post subject: Add User to Ignore List Reply with quote
Hi Allan,
Many thanks for the reply. I'll try to post some pictures.
The bungalow is 13 years old and has always had a combi boiler, so there's never been a hot water tank in the cupboard which is only about 18" deep.
There's nothing coming off the pipes at the bottom they just make a 'u'shape into the cupboard and go back up into the loft where they're joined to the rest of the heating system.
Louise
Back to top
Jaeger_S2k
PostPosted: Tue Aug 28, 2007 5:12 pm    Post subject: Add User to Ignore List Reply with quote
If it is simply, dropping from either feed or return and into the cupboard and continuing the feed or return then I'd remove the 'U'.
The other consideration may be the valve at the bottom was for easy drainage of that part of the system, might be worth considering that when you remove this U?
Jaeger.
FSBF
Back to top
Bludall
PostPosted: Tue Aug 28, 2007 5:33 pm    Post subject: Add User to Ignore List Reply with quote
That is exactly what my husband has been thinking. My camera's on the blink so I've failed to get the photos. But you've just confirmed what we thought.
Thanks.
Louise
Back to top
Bludall
PostPosted: Tue Aug 28, 2007 6:05 pm    Post subject: Add User to Ignore List Reply with quote
Fingers crossed this works.
Louise
Edited by uhm to add image tags Wink
Back to top
Jaeger_S2k
PostPosted: Tue Aug 28, 2007 6:18 pm    Post subject: Add User to Ignore List Reply with quote
Lop it out! Confused
Jaeger.
FSBF
Back to top
bathstyle
BATHROOM DESIGN AND INSTALLATION
PostPosted: Tue Aug 28, 2007 6:20 pm    Post subject: Add User to Ignore List Reply with quote
Who said Bathroom were easy eh Bludall Laughing
I would want to have a look above the airing cupboard before cutting it out.
Back to top
Bludall
PostPosted: Tue Aug 28, 2007 6:25 pm    Post subject: Add User to Ignore List Reply with quote
Thanks Allan.
Bathstyle,
Do you think there's more to it than a loop on the heating system?
The other suggestion from my husband was to just re-route the pipes so that they face the door rather than the left-hand wall, allowing the cupboard to be much smaller depth wise.
Louise
Back to top
bathstyle
PostPosted: Tue Aug 28, 2007 6:31 pm    Post subject: Add User to Ignore List Reply with quote
Have a look in the loft , I reckon it can just be cut out in the loft space.
Difficult to tell without a loft pic Wink
Back to top
Bludall
PostPosted: Tue Aug 28, 2007 6:34 pm    Post subject: Add User to Ignore List Reply with quote
I'll have to get the ladder and have a look.
Watch this space.
Louise Smile
Back to top
Jaeger_S2k
PostPosted: Tue Aug 28, 2007 8:30 pm    Post subject: Add User to Ignore List Reply with quote
Rolling Eyes
Jaeger.
FSBF
Back to top
Bludall
PostPosted: Tue Aug 28, 2007 9:22 pm    Post subject: Add User to Ignore List Reply with quote
Allan,
How did my photo get on there?
Louise Embarassed
Back to top
Jaeger_S2k
PostPosted: Tue Aug 28, 2007 9:29 pm    Post subject: Add User to Ignore List Reply with quote
Laughing
Jaeger.
FSBF
Back to top
Hinton Heating
Gas/Heating Expert
PostPosted: Wed Aug 29, 2007 7:29 am    Post subject: Add User to Ignore List Reply with quote
it'll be fine to by pass the loop...
www.hintonheating.com
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers All times are GMT
Goto page 1, 2  Next
Page 1 of 2
