It is currently Thu May 24, 2012 9:35 pm
PostPosted: Fri Dec 23, 2011 4:25 pm
Hi
Can anyone tell me where I can purchase guttering for this log cabin I have? As you can see the distance from the fascia board to where the rain runs off means I can't attach guttering as would not catch the rain!
Any ideas or contacts greatly appreciated.
PostPosted: Fri Dec 23, 2011 9:17 pm
Has thanked: 15 times
Been thanked: 161 times
That type and style of roof was never meant to have gutters fitted, hence the long overhang.
If in hindsight you knew of the problem then before the roof had the covering fitted you could have fitted some 35mm x 100mm timber via screws from above.
If the decking is 18mm then you could retro fit some Rise and fall gutter brackets, by modifying them slightly and screwing to under side of roof with 15mm screws.
PostPosted: Fri Dec 23, 2011 9:24 pm
Hi
Thanks for the reply.
This is the link to the cabin I have bought. http://www.tigersheds.com/product_detail.asp?prod=184
They do sell guttering kits to go with this cabin, but at the time I decided not to purchase, hence the problem I have now when it came to buying the bits I need in! :cb
