simpson93 wrote:
emm im pretty sure the neon is prewired off the outcoming feed, with the guts of the neon pre wired, have you got a pic?
Here it is. Its a little fuzzy due to the limitations of my camera phone. The neon is at centre of the assembly with the wires permanently connected (pre-wired, as you say). The CPC is connected to the Neutral Out and the usual terminal on the back plate. In case your wondering why the RH screw is fitted upside down, it doesn't have a retaining washer so I temporarily hung it upside down through the hole to prevent loss.
Anyway, it works. Its a good warning against leaving the loft lights on or accidentally switching them on with the hatch closed.
Kev
