It is currently Wed Jun 20, 2018 11:46 pm
Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sat May 17, 2014 7:48 pm
Has thanked: 222 times
Been thanked: 174 times
Evening all!
Progressing slowed with the floor excavation as I treated the wife to 4 days break in Portugal for completing her 1st year of her 2year part Master's Degree.
Spent today digging though and now 3/4 complete!
The solid floor construction is planned for the front hall (Striped Red in Sketch), Dining Room and middle hall (Striped Green in Sketch).
Both halls will have the same solid OAK flooring as the Living Room which has 18mm plywood on a suspended floor.
The dining room will be finished with underlay / carpet.
I have a few questions:
1. As can be seen in the layout drawing the front hall (Striped Red in Sketch) & middle hall (Striped Green in Sketch) are both adjacent to the living room which has the suspended floor.
Do I need to build a breeze block/brick retaining wall up to retain all the solid floor construction materials? If so, What height do I need to bring this up to? Screed height? Strip foundation required for this small wall?
2. The front hall currently can be accessed from the dining room and living room – however I plan to remove the dining room door frame and brick up this opening. Would you suggest I build this wall on top of the concrete over site as opposed to ontop of the floor screed?
3. Main electrical supply cable which is in a duct cross the dinning room floor as can be seen in the photograph - bottom right hand. Should these be below the concrete over site? OK if lowered to within the type1 height?
Thanks in advance!
PostPosted: Fri May 30, 2014 9:55 pm
Thanks goes to CB for answering my questions on solid floor construction. As a small gesture of gratitude I donated to RLNI Eyemouth and Erskine Veterans who were the chosen charities of a classic mini event I attended at the weekend.
To summaries solid floor construction:
150mm type 1 mot ( hardcore ) compacted.
25mm sand blinding.
1200 gauge visqueen.
100mm concrete over site. 6ballast : 1 cement
100mm solid floor insulation.
Slip coat visqueen. Thin gauge polythene
75mm floor screed with glass fibres added to mix. 4Sharp sand:1 cement
25mm insulation around edges sitting on 100mm insulation coming up to finish floor level.
I have since completed the excavation 450mm deep with the help of a micro digger that I brought in through the window! Soil was very heavy clay and was a doddle to the wee machine! I know that it is not advised to operate equipment indoors - so I took both windows out from this room & the front door was open to ensure adequate ventilation.....
I have since received the delivery of all the material so this will keep me busy over the next couple of weekends...
PostPosted: Sat May 31, 2014 9:46 pm
5 bulk bags of type1 down...3 to go!
Put first layer in at 75mm thk. Then ran over with the whacker plate & have since started adding another 75mm layer!
Hopefully get the type1 finished & sand blinding & DPM done tomorrow.
Ready for the concrete over site next weekend.
PostPosted: Mon Jun 16, 2014 7:57 pm
Had words with the builder at the weekend as my wife wasn't happy with the speed to the project....
All type1 in & compacted 7 bags total, 1.5 bags of building sand compacted. Concreted the strip found & built two course of 7N breeze block to act as a retaining wall at the hall to living room transition. Started to lay the DPM, need to tape up the joints then cut & lay the reinforcing mesh one night this week ready for concreting on Saturday...
PostPosted: Mon Jun 16, 2014 8:34 pm
Has thanked: 1444 times
Been thanked: 3690 times
:dunno: Which one is you :scratch: :scratch:
PostPosted: Mon Jun 16, 2014 9:16 pm
The one with the hat hard on....
PostPosted: Wed Jun 18, 2014 4:30 pm
Wood Flooring Installer
Has thanked: 552 times
Been thanked: 642 times
Reminder : This is a family forum :lol: :lol: :lol:
fitmywoodfloor.co.uk
Squeakyfloorsolution.co.uk
>>>>>> Manchester based wood floor installers <<<<<<
PostPosted: Wed Jun 18, 2014 11:25 pm
Alan Partridge would be proud though....
For this message the author getthewheelsinline has received gratitude : Wes
PostPosted: Sun Jun 29, 2014 10:19 pm
Enough of my hard hat...
Got the Damp Proof Membrane down & all joints double taped with 200mm overlap.
Cut the A252 reinforcing mesh to suit the room dimensions. I was restricted by the front door opening size so had to tie the mesh together with wire.
Also sat the mesh on plastic chairs which make it a doddle to keep at a consistent height - I opted for spacers which allowed the mesh to sit 40mm above the dpm.
On with the 100mm concrete over site mixed at a ratio of 6ballast to 1 cement.
My wife mixed the lot while I wheel barrowed & levelled...mid progress snap....
5 bulk bags of ballast later & we were finished at 11pm... Both shattered!
Floor is level within 3-5mm however a fair few trowel marks remain as sadly didn't have a large bull nose trowel to hand!!! Thinking of getting a concrete planner to just nip these so the foil insulation is placed onto concrete surface that is 100% smooth...
Got 3days off this week so hopefully will manage to crack on with over-boarding the ceiling then framing & plaster boarding the walls!
PostPosted: Mon May 04, 2015 9:20 pm
Howdy! Not updated this thread in a while... I'll let the photos do the talking... Bar the gas connection & carpet laying my between my wife & I we have done 99% of the work ourself! Any questions / comments fire away...
Dining room photos first just for continuation of last post...
PostPosted: Mon May 04, 2015 9:24 pm
Back to the living room...
Engineered flooring acclimatising before installation this weekend!
PostPosted: Mon May 04, 2015 9:33 pm
Front porch...
PostPosted: Mon May 04, 2015 9:40 pm
Front hall...
PostPosted: Mon May 04, 2015 10:14 pm
Apologies for the order of some of the photos... I was uploading them via my phone.
Special Thanks go to the following members;
Cotswold builders for the general building guidance
Wes for the floor substrate & flooring guidance
Dynamod for the decorating guidance
Top blokes!
For this message the author getthewheelsinline has received gratitude : cotswold builders
PostPosted: Wed May 06, 2015 7:49 am
Meant to add these to the front porch post....
Original window surround was coloured concrete (pink!!) so ripped this out for real sandstone...
Bought this window on gumtree which is the correct height but double the width - so plan to reduce it....
