It is currently Thu May 24, 2012 9:28 pm
 Post subject: Location of shower pump
PostPosted: Fri Oct 21, 2011 7:29 pm
Has thanked: 1 times
I have a gravity fed system and the water pressure for my shower has never been good, but I have put up with it, as I am sure we all do.
I now would like to install a pump to boost pressure. I do not want to have an electric/power shower as I am happy with the shower fittings I already have.
I have a very good supply of hot water, so that will not be a problem.
The problem I do have is where to locate the pump. My airing cupboard is so tiny and I am struggling to think of anywhere else that will be easy to connect. One thought was to put the pump in the loft. For normal pumps I am informed that will not work because there won't be any head of water. Are there any pumps that are especially designed to overcome this problem?
Fenders
PostPosted: Fri Oct 21, 2011 7:57 pm
Has thanked: 25 times
Been thanked: 71 times
Stuart Turner Showermate U1.8 bar twin pump is designed to boost the incoming hot and cold water supply to an individual shower, bath / shower mixer, or tap in negative head plumbing systems is one example.
For this message the author aeromech3 has received gratitude : Fenders
PostPosted: Sat Dec 03, 2011 2:51 pm
Thanks Aeromech. Brillaint pump.
Users browsing this forum: No registered users and 9 guests
