It is currently Fri Sep 21, 2018 1:01 pm
 Post subject: Lighting timers, sunset
PostPosted: Fri Aug 25, 2017 8:45 pm
Has thanked: 18 times
Been thanked: 2 times
Hi all,
I have some external decorative lights (up/down lighters) on my house that are currently on a Kingshield timer. It does the trick but it's a bit of a fiddle to program and as the nights draw in I'll need to change it a few times to come on at the right time.
I'm wondering if there's any product available that automatically tracks the sunset? I have something similar on an IoT smart plug, but I've not seen anything similar for an electrical timer. Does anyone know if such a product exists or am I dreaming?
Thanks!
PostPosted: Fri Aug 25, 2017 8:48 pm
Has thanked: 1119 times
Been thanked: 1034 times
http://www.screwfix.com/p/standalone-ph ... 7QodmtgDfw
Read the reviews. Somebody has a timer connected as well/
PostPosted: Fri Aug 25, 2017 8:50 pm
UHM Super Moderator
Has thanked: 56 times
Been thanked: 91 times
I've moved this to Lighting.
PostPosted: Fri Aug 25, 2017 8:56 pm
Has thanked: 45 times
Been thanked: 1334 times
I have a couple of them. If you have a timer too, you have to wire the photo cell in AFTER the timer (You don't have to but otherwise you have to use relays, and a box and it gets messy) Then when the timer says come on, it powers the photo cell, and if the photo cell says its dark the lights come on.
If the photo cell says its too light the lights will not come on until its dark enough.
By using a timer and a photocell the lights will come on at a specific time, but they will also switch off at a specific time (say 00:00)
The down side is that if it is light and the timer says come on, the lights will come on for around 1 minute while the photocell warms up (It really does warm up because it uses a small heater and bi metallic strip)
For this message the author someone-else has received gratitude : wickedwjc
PostPosted: Fri Aug 25, 2017 10:03 pm
Approved Electrician
Has thanked: 165 times
Been thanked: 578 times
You should use a voltage free switched timer and feed the output of the photocell through the timers voltage free switches.
Or there is this
https://www.sangamo.co.uk/products/q551 ... 1085910022
And photo cell heads are available that will turn off at midnight with no programmer.
PostPosted: Fri Aug 25, 2017 10:42 pm
£175 :shock: It may be the RollsRoyce of timers, but I bet the OP wont want one of them.
I can't think why, but I could not do that.
PostPosted: Sun Sep 03, 2017 7:46 pm
Thanks everyone for your replies - very helpful and seems I've got a couple of options...
I've found a Finder module for under £50 with an "astro switch" function (basically works out sunset based off co-ordinates and time) which although more expensive than the photocell option should be easier for me to fit.
Cheers!
Users browsing this forum: cerenko and 0 guests
