It is currently Thu May 24, 2012 9:14 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
PostPosted: Thu Dec 22, 2011 3:12 pm
Has thanked: 1 times
Hi guys,
I need help. :scratch:
I have a dimmer switch downstairs with 2 switches, one controls the kitchen light and one controls the dining room light. This single switch is the only way to turn the lights on in these two rooms - they are not wired up to any other switches and we can turn each room on independent of the other. My wife switched one of them on t'other day and the switch itself went bang and tripped the circuit breaker.
I got a new switch and fitted it exactly the same way but the circuit breaker will not go back on!!
I thought I'd try fitting a normal switch to make sure I hadn't purchased a duff dimmer switch but I'm a bit baffled how to fit it.
Please see my attached diagram.
Can anyone advise??
Thanks,
Paul.
File comment: Impressive huh?
PostPosted: Thu Dec 22, 2011 5:00 pm
Has thanked: 166 times
Been thanked: 613 times
I see your skills with paint are better than mine....
So red to L. Black from the respective cable to L1..
:thumbright:
For this message the author wine~o has received gratitude : fearthegrimp
PostPosted: Thu Dec 22, 2011 5:10 pm
Thanks..Thought it must be simple but electricity is scary!! :?
PostPosted: Thu Dec 22, 2011 5:13 pm
Indeed..Lecky off first though...(Oh it already is... :lol: :lol: )
PostPosted: Thu Dec 22, 2011 5:26 pm
Thanks but no luck :sad:
Does that mean the circuit breaker has blown and needs replacing?
I've tried 2 different switches now, a dimmer and a normal one but the circuit breaker will not go back up.
PostPosted: Thu Dec 22, 2011 5:29 pm
Try switching the main RCD off, then reset the mcb for the lights, then switch the rcd back on again...If that doesn't work then there is another problem somewhere...
PostPosted: Thu Dec 22, 2011 5:38 pm
Tried switching the main switch off on the fuse board....all elec went off as expected but the downstairs circuit breaker still wouldn't go up. Switched power back on and still wouldn't go up.
Does that give any more clues?
Ta!
PostPosted: Thu Dec 22, 2011 5:44 pm
Remove all the bulbs from the light unit that was being switched when you had the bang..you may find an edison screw lamp with a dead short, then try the above again..
PostPosted: Thu Dec 22, 2011 6:11 pm
Ta!
Having re-thought, sounds like the Mcb if fecked..unusual though not unheard of..
Try again with main switch off and be fairly bold with the lighting circuit Mcb..
PostPosted: Thu Dec 22, 2011 8:20 pm
Looks like the circuit breaker is goosed! Bro-in-law just had a look and wired the downstairs into the upstairs light circuit temporarily...
Well diagnosed Wine-O!! Thanks..
Users browsing this forum: No registered users and 9 guests
