It is currently Thu Feb 21, 2019 8:03 pm
 Post subject: light keeps failing
PostPosted: Tue Aug 07, 2018 2:44 pm
Hi there,
I'm looking for advice about a problem I keep having in my bungalow. The light in my bedroom keeps failing. It happened last year, the electrician put it right but it's happened again so I think there may be an issue that the electrician missed. I'd like to ask if anybody has any ideas what the problem may be before I call an electrician again.
Last year, the light was initially switching on OK, then, after 10 minutes or so, it started going out for a few seconds, then coming back on for a few seconds, then out, on, out, on... I changed the bulb, the same happened. The electrician came. He said it was the bulb despite it being new. He changed the bulb again, and the light worked well for a year or so, until now...
Then, a few days ago, I could no longer switch the light on. As I pulled the switch, I got a very brief flicker of light and then it went out immediately. I have changed the bulb. The same problem kept happening. Now, the switch doesn't have any effect: the light does not come on at all.
So, has anybody got any idea of what is happening? Is there something I should look for or be aware of before calling an electrician?
None of the other electrical items in the bungalow is causing a problem. I have had solar panels installed between the two series of incidents - in case this could be relevant -.
Any ideas?
 Post subject: Re: light keeps failing
PostPosted: Tue Aug 07, 2018 3:47 pm
Has thanked: 1531 times
Been thanked: 3852 times
:welcomeuhm:
what type of bulb ? 12 Volt or mains ? if unsure take a pic of the bulb and post it up.
