It is currently Mon Feb 18, 2019 10:17 am
PostPosted: Wed Jul 11, 2018 12:44 pm
Has thanked: 86 times
Been thanked: 58 times
My new chargers are classed by makita as 'fast' chargers; they have a charge time (for 5.0Ah) of 45mins, which is nearly 2.5x the rate of their 'standard' charger. That is exactly what I want for some applications, and much faster than I'm used to.
But.. we know that high charge rate (not just discharge rate) affects battery longevity. Very often (probably most often) I could get away with charging at the 'standard' rate if there were good enough reason.
Yet.. 45mins is still about three times more gentle than the worst of my tools will discharge at, so isn't extreme by any means; not sure if it is fast enough to even worry about. Does anyone think its worth getting additional standard rate chargers for use when speed is unimportant? (they cost around £25 each, but I'd need at least a couple).
Kev
PostPosted: Wed Jul 11, 2018 6:57 pm
Has thanked: 349 times
Been thanked: 1823 times
Well given that the only people to 'really' benefit from fast charging are the people that sell the batteries......
If you have a theoretical lifespan for the battery of 500 charge/discharge cycles and fast charging reduces that by (say) 20% will you be concerned for having a battery that only lasts 400 cycles?????
PostPosted: Wed Jul 11, 2018 9:15 pm
Old School Chippie
Has thanked: 784 times
Been thanked: 1559 times
In a word, no! Simply put Li-Ion batteries will deteriorate at 5 to 10% of their charge capacity for every year of their life - regardless of whether or not you use them. On top of that fast charging can reduce charge capacity a bit more. The question has to be, "just how long do you expect your batteries to last?". In trade use I'd say that everything over 3 years is a bonus and that that should be your target write-down time, as well as being a lifespan which will keep your batteries being within reasonable charge capacity. I'm afraid that when my 5Ah batteries get down to 70% (3.5Ah) capacity then that will be the time to transfer them to lighter duties, such as for DIY at home where 50% or even 30% of the original capacity won't make much difference. At work having to stop for 20 minutes or more while I walk down to the charge point and then return, maybe 3 times a day, is quickly going to cost me far more than the price of a few new batteries. With some of my 5Ah batteries now approaching 3 years maybe it's time I got the local Makita service dealer to do a battery test - what is certain is that they certainly don't give the same run time as long as my new batteries, although I haven't yet quantified the difference
For this message the author Job and Knock has received gratitude : Kev888
PostPosted: Wed Jul 11, 2018 10:22 pm
Thanks both, those are exactly the kind of things I was trying to get a feel for.
Yes, after 3years the batteries could be down to about 75% capacity in any case, even having done very little. Though (as another thread suggested) they are less than a year old when I bought them, so hopefully I've got at least a couple of years before 5ah become <4ah through age alone. My experience with some that I used only occasionally (due to being small capacity) suggest maybe ~7%/yr deterioration or a tad less is about right.
So in comparison to the high discharge tools and the ageing thing, the difference between modest and higher charge speeds isn't going to be great. TBH i suspect having standard rate chargers over enough batteries and enough years would still see notable savings, but weighed against the inconvenience and cost of having to double up on chargers and extend charging time, I shall put the idea to bed.
Thanks again.
Kev
PostPosted: Wed Jul 11, 2018 10:29 pm
Has thanked: 700 times
Been thanked: 2026 times
if time and space are at a premium then having to transfer say 3 x5ah batts rather than 5 x5 ah may be a no brainer with the additional "running cost" having to replace your batts more often will be more than offset time and convenience wise
PostPosted: Wed Jul 11, 2018 10:47 pm
Yes, I agree. The biggest factor for me was that fast chargers would allow continual working with about 6x batteries, whereas standard chargers would need double that number.
In my case its only going to be an occasional thing, to use batteries so heavily and continuously (which is why slow charging would so often be an option). But that makes doubling up on batteries even less desirable, given how they age when being lightly used normally.
Kev
PostPosted: Wed Jul 11, 2018 11:02 pm
another point to note
cycling your batteries can give a bit more run time within the same day as in a battery will go "flat" in a high draw brushless tool but in actual fact have enough left for say a fan/driver/light for a few hours
so providing all batts are equally charged rather than plonk on charge swop first with a low draw tool making sure you have a spare fully charged battery in case :lol:
i mark all batteries and take note off batteries when they go flat which over time will tell you the best and worst batteries by number
another good thing about li-ions is you can plonk them on charge any time and short charge them
so you get on site with say 3 batts all fairly flat as you forgot to charge them :lol:
you dont need any down time till the charge cycle finishes you just take it off charge iff you need it placing another on charge when you do and hopefully can catch up as you go :lol:
For this message the author big-all has received gratitude : Kev888
PostPosted: Thu Jul 12, 2018 9:06 am
Has thanked: 1 times
Been thanked: 46 times
Just a small point when in days past I used to race model boats and cars, we always ensured that the battery pack was fully discharged before we put them back on charge, this was done with a 12vlt car bulb with two wires soldered to it (+ - ) take the battery out of car/boat and connect to the bulb, that will then "drain" off any power left, when the bulb is out then re-charge the batteries. I assume it is the same today :dunno: Nos
PostPosted: Thu Jul 12, 2018 9:32 am
quite different with li-ons :lol:
they have protection circuits to hold a small charge and stop them going flat because if they go flat thats it they are dead and will not charge
PostPosted: Thu Jul 12, 2018 6:16 pm
Old School Chippie
big-all wrote:
...so you get on site with say 3 batts all fairly flat as you forgot to charge them :lol:
The issue of charging on site is always a contentious one. Where I'm currently working it can mean a 15 minute round trip to get from an un-powered work area area to the charger station then back again - always providing you are willing to leave batteries on charge with their charger(s) in an unsecured location (I'm not) - which makes having a day's worth of 5Ah batteries a no brainer. Sometimes I work where the power supply is relatively near, but over the past 5 years that's been the exception rather than the rule for me.
Nos wrote:
Just a small point when in days past I used to race model boats and cars, we always ensured that the battery pack was fully discharged before we put them back on charge.....
As B-A says, Li-Ion is a different beast altogether. In addition to his point manufacturers often recommend that it is more efficient (causes less degradation of the battery?) to recharge a battery when it is about 80% discharged than to deep discharge it. You are also advised to store Li-Ions fully charged if at all possible
PostPosted: Fri Jul 13, 2018 8:25 am
Thanks guys it was ni-cads that were the "new" batteries in my day. Nos
PostPosted: Sun Jul 15, 2018 8:14 pm
Has thanked: 1529 times
Been thanked: 3848 times
Li-ions don't have the same "memory effect" as Ni-Cads.
