Ultimate Handyman Home
led light bargain
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Electric Forum UK -> Lighting
handyman
PostPosted: Wed Aug 13, 2008 8:29 pm    Post subject: led light bargain Add User to Ignore List Reply with quote
http://www.screwfix.com/prods/59775/Lighting/Outdoor-Lighting/Outdoor-Wall-Lighting/Stainless-Steel-LED-Wall-Lantern-IP44-176mm;jsessionid=BJEG24SNQMBO4CSTHZPCFFA?ts=58895
put a few of these up at my house, and they are superb. I'm now replacing my 11w dusk dawn lights with them as well.
They only draw 1.5w and are fine for a dull general dusk dawn security lighting in the garden/garden gate/ drive enterance/shed door (I've went a bit ott Laughing ) as you get 7 lights burning for the price of the one at the front door.
Go on, adopt a greyhound http://www.dgrescue.org.uk/ ..........................................................................
Back to top
Stoday
Electricity economics consultant
PostPosted: Wed Aug 13, 2008 9:37 pm    Post subject: Re: led light bargain Add User to Ignore List Reply with quote
handyman wrote:
They only draw 1.5w .
So why does the spec say "max 12±0.1W"?
scratch
УГМ МОД — Пошёл на хуй
Back to top
handyman
PostPosted: Thu Aug 14, 2008 6:41 am    Post subject: Add User to Ignore List Reply with quote
ok, its 1.2w............its got 12 x 0.1 leds which are concentrated onto a funky looking reflector which then throws the light out
for only a 1.2w draw, its amazingly good
Back to top
IDontBelieveIt
Approved Electrician
PostPosted: Thu Aug 14, 2008 6:54 am    Post subject: Add User to Ignore List Reply with quote
Picking up on Stods comment HM - the specs state
"230V 50Hz. H x Dia. 176 x 76mm, extension 143mm. 12 LED max 12±0.1W.
So that really IS 12 watts. Do you mean 1.2 watts per LED? in which case agreed (ish)
A few things about these low watt lamps LED's included HM -
They don't work with the average dusk to dawn sensor and they don't work with most dimmers either because most dimmers and sensors have a minimum holding current and these low energy lamps are well below this minimum.
If you try to circumvent the minimum holding current problem with a dimmer and say fit a single GU10 on the circuit the LED lamps will last about 2 weeks then they will blacken and die.
Never lie - that way you don't have to remember what you said.
Back to top
handyman
PostPosted: Thu Aug 14, 2008 7:00 am    Post subject: Add User to Ignore List Reply with quote
balls Embarassed not as good as i thought Embarassed ..........and why its better than i thought it would be
looks really nice though Laughing
So, all i have done is change the horrible light units i had with nicer ones, and not saved any energy
they appear to work with the dusk till dawn sensor fine...........dont get why it wouldnt? I understand the dimmer not working, but not why the dusk/dawn wouldnt work. Just got one lamp connected to a dusk/dawn in back garden, so is drawing very little. Must just be ok with it (a bnq special Laughing )
Back to top
handyman
PostPosted: Thu Aug 14, 2008 7:08 am    Post subject: Add User to Ignore List Reply with quote
this type of thing made me read the spec wrong
http://www.screwfix.com/prods/24624/Lighting/Lamps/LED-Lamps/LED-Lamp-GU10-Warm-White
20 leds and 1w draw.......meaning each led is .05w?
Back to top
Stoday
PostPosted: Thu Aug 14, 2008 9:45 am    Post subject: Add User to Ignore List Reply with quote
Does the package quote the lumen output HM?
If it doesn't, then Screwfix is not complying with The Energy Information (Lamps) Regulations 1999, SI 1517.
Naughty!
Back to top
handyman
PostPosted: Thu Aug 14, 2008 10:47 am    Post subject: Add User to Ignore List Reply with quote
looked at the light, box and instructions, and there is nothing on them to say the lumen output or the watts of the unit.
Have e mailed then so they can confirm the watts.........
Back to top
IDontBelieveIt
PostPosted: Thu Aug 14, 2008 11:09 am    Post subject: Add User to Ignore List Reply with quote
The reason it works with the dusk > dawn sensor HM is, probably, due to the sensor using a relay to switch the load rather than a triac/scr (which is why most dimmers have problems with low energy loads as they tend use triacs).
Back to top
handyman
PostPosted: Thu Aug 14, 2008 11:30 am    Post subject: Add User to Ignore List Reply with quote
yes.......it does make a 'click' when it switches on........that will explain it
Back to top
handyman
PostPosted: Thu Aug 14, 2008 3:48 pm    Post subject: Add User to Ignore List Reply with quote
sfd emailed back and say then need to look into this further. He did say that 1.2 watts sounds correct, and I cant find any 12 watt led lights (ie 1 watt x 12 clusters)
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Electric Forum UK -> Lighting All times are GMT
Page 1 of 1
