Page 1 of 1
[ 2 posts ] |
| Author |
Message |
GingerD
Posted: Wed Sep 28, 2011 2:13 pm |
| Newly registered Member |
Joined: Wed Sep 28, 2011 2:05 pm Posts: 1 Has thanked: 0 times Been thanked: 0 times
Hi All,
Got a problem hoping someone can help with.
I've got a property that has a few small leaks in the roof.
The tiles appear to be concrete interlocking tiles and a ridge tile.
There's a fair amount of moss between the tiles in places.
There are a number of ventilation pipes and a chimney exiting through the roof.
What's the best solution to my leaks and what's the best way to trace them. I suspect one is coming from where the chimney exits the building but the other two, I've not got a clue where they're coming from, but they end up about three feet from the edge of the pitched roof.
Is there a sealant I can use?
| Top |
northwales4u
Posted: Thu Sep 29, 2011 11:15 am |
| Senior Member |
Joined: Sun Jul 25, 2010 5:32 pm Posts: 2181 Location: Wrexham, Wales Has thanked: 45 times Been thanked: 124 times
Perhaps some pics of where you suspect it to be leaking will help. Can you see any broken/cracked tiles?
| Top |
register or
log in
Page 1 of 1
[ 2 posts ] |
