Ultimate Handyman Home
leaking sink
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum
brokensink
Junior Member
PostPosted: Tue Mar 25, 2008 9:14 pm    Post subject: leaking sink Add User to Ignore List Reply with quote
Hi there,
My DIY plumbing skills are still at a novice level. My sink is leaking quite seriously at the point indicated by the red arrow. Can I fix this with duck tape or plumbing tape or by some other means? Is there some sort of anti-leak glue or sealant I can use?Buying a new sink is not an option.
Many thanks! Help
Back to top
thescruff
PostPosted: Tue Mar 25, 2008 9:42 pm    Post subject: Add User to Ignore List Reply with quote
Just take it to bits (screw in the middle) clean everything and put it all bacl together.
Looking at you pic the waste is out of line as though something has bumped or knocked it.
If you dry it well you could put a bead of silicon, instead of the washer, on the flange that sits in the sink, do not put anything underneigh other than the big washer.
Scruff
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum All times are GMT
Page 1 of 1
