It is currently Wed Oct 17, 2018 1:58 pm
PostPosted: Sun Oct 29, 2017 3:33 pm
Been thanked: 2 times
My rising main stop tap leaks at the gland. The screw holding the handle on is seized solid. I can take off the valve. Buying a new tap and only using the valve seems the simplest solution. The house was built in 1980 , will a new valve fit the existing housing please. I don’t want to risk taking off the complete tap. Thanks , Mike
For this message the author Radnorboy has received gratitude : multiman
PostPosted: Sun Oct 29, 2017 4:21 pm
Has thanked: 210 times
Been thanked: 148 times
Hi Mike, a picture would definitely help in this case. What's the diameter of the pipes either side of the stop clock?
For this message the author Ktuludays has received gratitude : multiman
PostPosted: Mon Oct 30, 2017 10:33 am
Member
Been thanked: 39 times
You can usually fix these without taking of the handle:
1. Open valve fully. Clean / polish spindle with green washing up pad type fine abrasive. (Gets rid of limescale, corrosion and makes the spindle smooth)
2. Close valve fully.
3. Undo gland nut and pull out onto spindle.
4. Make "string" of PTFE tape by twisting a length (start at around 4" / 100mm) tightly.
5. Wrap PTFE string around spindle in the direction the gland nut will tighten.
6. Push down and re-tighten gland nut.
7. If not sealed, repeat 3. to 6. above with increasing lengths of PTFE.
For this message the author andy48 has received gratitude : multiman
PostPosted: Mon Oct 30, 2017 3:22 pm
Thanks for your replies, I did what you suggested andy some time ago and want to do a more permanent job now. I have found that my main stopcock at the end of the drive doesn't shut off so will wait for SWWater to fix that.
P.s I would like to 'thank you' but can't find how to do it.
PostPosted: Mon Oct 30, 2017 3:38 pm
UHM Super Moderator
Has thanked: 56 times
Been thanked: 92 times
The "Thanks" button is (or should be) in the right hand group of buttons at the bottom of each post.
For this message the author moderator7 has received gratitude : multiman
PostPosted: Tue Oct 31, 2017 10:15 am
Has thanked: 696 times
Been thanked: 28 times
Otherwise freeze pipe and replace.
