| Author |
Message |
Alburly
Posted: Sun Nov 06, 2011 7:08 pm |
| Newly registered Member |
Joined: Sun Nov 06, 2011 6:44 pm Posts: 8 Has thanked: 0 times Been thanked: 1 times
I have a Vokera combi boiler that's a few years old and gets serviced once a year.
Sorry, I should have said hello first. New to this forum.
My problem: for a few years now water drips from the flue, sometimes not always. It's rusty in colour and leaves a horrible rusty mark on the roughcast. The flue is bent inward, ie curved round to face the wall. Overtime the roughcast has become damaged and needs repaired. When we asked the engineer about the dripping he replied, it's supposed to drip.
Can anything be done to prevent this?
Thank you for any help or advice given.
| Top |
moderator6
Posted: Sun Nov 06, 2011 7:23 pm |
| UHM Super Moderator |
Joined: Mon Aug 08, 2005 10:43 pm Posts: 778 Has thanked: 24 times Been thanked: 63 times
Hi Alburly Alburly wrote: The flue is bent inward, ie curved round to face the wall. I think the guys will want to see a picture of that. Sounds rather unusual
| Top |
register or
log in
thescruff
Posted: Sun Nov 06, 2011 8:52 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39983 Has thanked: 187 times Been thanked: 2113 times
Make and model of the boiler would be a good plan as well as a pic of the flue.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
Argyll
Posted: Sun Nov 06, 2011 9:15 pm |
| Senior Member |
Joined: Wed Sep 10, 2008 4:58 pm Posts: 296 Has thanked: 49 times Been thanked: 4 times
Hi Alburly,
Are you sure it's the flue and not just the overflow pipe?
| Top |
register or
log in
gas4you
Posted: Mon Nov 07, 2011 12:16 pm |
| Senior Member |
Joined: Mon Apr 13, 2009 8:03 pm Posts: 3577 Has thanked: 51 times Been thanked: 230 times
Sounds like the prv outlet to me and no it should not be dripping. The flue will be the large 4" pipe off the top of the boiler and can't imagine this ever turned back towards the wall
_________________ Dave
www.drlgas.co.uk
| Top |
register or
log in
Alburly
Posted: Mon Nov 07, 2011 8:07 pm |
Oops sorry guys. It must be the overflow pipe/outlet that's bent inward towards the wall. Sorry for the confusion. It's roughly about 20-25mm in diameter. The wall is stained with a rusty water mark and has caused damage to the roughcast. Is there anyway in which this can be prevented?
Many thanks for your replies and advice.
| Top |
register or
log in
thescruff
Posted: Mon Nov 07, 2011 10:53 pm |
| OAP |
That will indicate a fault with the PRV or more likely the expansion vessel, or filler.
| Top |
register or
log in
Alburly
Posted: Tue Nov 15, 2011 7:49 pm |
Many thanks for your advice. The service engineer came out yesterday and said that it's supposed to do that? hmm!
The problem is that it's damaging the rough casting, as the boiler overflow is upstairs in the house. Is there anyway in which the overflow could be extended? I was thinking of bringing a pipe up and over the overflow. This would take the rusty water down and away from the rough casting. If this is possible, what is the best type of pipe to use?
Thank you once again for your advice.
| Top |
register or
log in
thescruff
Posted: Tue Nov 15, 2011 7:59 pm |
| OAP |
Can you post a pic please, without the info I would say the service engineer is talking absolute poppycock
Edited by Mod 6
| Top |
register or
log in
Alburly
Posted: Sat Nov 19, 2011 6:58 pm |
Thanks for your reply the scruff.
Please find attached a photo of the overflow and rusty water mark. The water mark is actually worse than what's shown due to the photo limitations.
Thank you once again for your help!
| Attachments: |
File comment: Overflow with rusty water mark on roughcast. Water mark is slightly worse than shown.
| Top |
register or
log in
thescruff
Posted: Sat Nov 19, 2011 11:06 pm |
| OAP |
What is it connected too the other side, it looks like the pressure relief valve is leaking.
How high does the pressure rise to when the boiler is running, and do you have to keep topping the pressure up.
| Top |
register or
log in
Alburly
Posted: Mon Nov 28, 2011 7:57 pm |
Many thanks for your help and replies. I'm afraid I haven't got a clue about boilers. I don't want to go messing about with them either.
In laymans terms, do you think something is wrong?
Would it be possible to extend the overflow down to prevent the brown water ruining the roughcast? For example, a pipe brought down the wall to take away the brown dirty water.
Thank you for your help and advice once again.
| Top |
register or
log in
Razor
Posted: Mon Nov 28, 2011 8:09 pm |
| Senior Member |
Joined: Wed Nov 14, 2007 10:21 pm Posts: 5140 Location: Northampton Has thanked: 76 times Been thanked: 372 times
It shouldn't leak or drip at all All Scruff asked you to do was see what the pressure guage on the boiler reads when it's cold and then check again when the systems been on for 20 minutes then tell us what you see
_________________ As always help on here is free, however if you think you have saved a decent sum of money why not click the link to find out about the charity we're currently supporting? A couple of quid makes a real difference. donnas-dream-house-charity-t52110.html
| Top |
register or
log in
joinerjohn
Posted: Mon Nov 28, 2011 8:13 pm |
| Senior Member |
Joined: Sun Nov 07, 2010 10:43 am Posts: 433 Has thanked: 2 times Been thanked: 26 times
If it is (and I suspect that it is) the PRV overflow, then it's in the regulations that it has to be turned into the wall (or run very close to the ground) Stops anyone getting blasted with boiling hot water should it operate due to too much pressure.
| Top |
register or
log in
Alburly
Posted: Sun Dec 11, 2011 3:39 pm |
Thanks for all your help and advice.
A couple of questions to put this to bed please!
Why is the water brown?
And if the brown water problem can't be fixed. Can the overflow be extended down the wall by using a pipe to take away the dirty water from the wall?
Finally, what type of pipe (material) and fittings could be used? If it's ever been done before?
Thank you.
| Top |
register or
log in
