It is currently Thu May 24, 2012 2:29 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sun Dec 11, 2011 4:20 pm
Has thanked: 9 times
Been thanked: 62 times
Alburly wrote:
Thanks for all your help and advice.
A couple of questions to put this to bed please!
Why is the water brown?
seems a sure sign of corrosion in your system
you could drain the system and refill it with appropriate amounts of inhibitor
And if the brown water problem can't be fixed. Can the overflow be extended down the wall by using a pipe to take away the dirty water from the wall?
Finally, what type of pipe (material) and fittings could be used? If it's ever been done before?
get a engineer in to sort the problem rather than bodging it to avoid the problem for a couple of days, either the PRV(pressure release valve) is passing or you exspantion vessle is empty meaning the pressure in teh system has nowhere to expand to so it is released out of you PRV more than likely its both
Thank you.
PostPosted: Sun Dec 11, 2011 4:21 pm
fail on quoting
PostPosted: Sun Dec 11, 2011 7:17 pm
OAP
Has thanked: 187 times
Been thanked: 2113 times
The brown water is from the system.
The PRV shouldn't be leaking, so you have a fault, possibly the expansion vessel, but we need the answers from previous questions.
