| Author |
Message |
royaloakcarpentry
Posted: Mon Feb 01, 2010 10:12 pm |
| Senior Member |
Joined: Sun Jan 24, 2010 1:48 pm Posts: 4152 Location: Essex Has thanked: 2 times Been thanked: 327 times
| Top |
Slayer
Posted: Mon Feb 01, 2010 10:18 pm |
| Senior Member |
Joined: Tue Dec 04, 2007 8:16 am Posts: 247 Location: Somerset Has thanked: 0 times Been thanked: 0 times
Am loving those. Nice work
_________________ It should fit, beat it with a hammer and try it again!
| Top |
register or
log in
royaloakcarpentry
Posted: Tue Feb 02, 2010 5:33 pm |
| Senior Member |
Thanks, Slayer. I need to get some big bathrooms so I can actually take proper pictures lol.
Should have a big wet room coming up soonish.
| Top |
register or
log in
Mooncat
Posted: Tue Feb 02, 2010 8:20 pm |
| Senior Member |
Joined: Sun Dec 23, 2007 4:11 pm Posts: 9928 Location: Wales Has thanked: 33 times Been thanked: 42 times
Neat!
A question: Why do these tubular towel rails have only 3 fixings? One of my two rails came with 4 so I used them. Very rigid, compared with the one I fixed with 3.
_________________ I started out with nothing, I still have most of it. Directmail scam information site: http://astrocat.proboards.com/index.cgi?
| Top |
register or
log in
royaloakcarpentry
Posted: Tue Feb 02, 2010 8:28 pm |
| Senior Member |
Hmmmm why three fixings? haven't a clue. Probably because that is what the manufacturer deems they need.
Three fixing points are plenty. You could use those to climb up and get into the loft if there was a hatch above them lol. (Well i wouldn't try it but you get the point).
| Top |
register or
log in
EJJ150847
Posted: Tue Feb 02, 2010 8:29 pm |
| Senior Member |
Joined: Fri Jan 04, 2008 10:32 am Posts: 3032 Location: Fareham, Hampshire Has thanked: 2 times Been thanked: 61 times
Verrrry Nice!!
John
_________________ Growing old is compulsory, growing up is not!
| Top |
register or
log in
deck
Posted: Tue Feb 02, 2010 8:31 pm |
| Senior Member |
Joined: Wed Aug 26, 2009 10:20 pm Posts: 664 Location: UK Has thanked: 0 times Been thanked: 3 times
Nice simple lines a job well done
dECK
_________________ Never eat yellow snow
| Top |
register or
log in
diyguys
Posted: Wed Feb 03, 2010 8:28 pm |
| Senior Member |
Joined: Fri Dec 11, 2009 6:32 pm Posts: 1481 Has thanked: 178 times Been thanked: 19 times
Great work as usual , you do fab work.
| Top |
register or
log in
DIY_Johnny
Posted: Sat Feb 06, 2010 10:51 pm |
| Mr. Grumpy |
Joined: Tue Nov 18, 2008 3:41 pm Posts: 2415 Has thanked: 0 times Been thanked: 32 times
well done, good to see.
Looks a lot neater when rad tails head into the wall rather than the floor. I should have thought of that,l when i did mine
I went the same and siliconed the internal corners. Gives me more confidence is waterproofing the floor
| Top |
register or
log in
rotciv
Posted: Mon Feb 08, 2010 10:30 pm |
| Senior Member |
Joined: Sat Apr 05, 2008 8:10 pm Posts: 810 Location: Malta Has thanked: 6 times Been thanked: 6 times
First class workmanship
_________________ Dreams contain the seed of success..... (if you manage to wake up.)
| Top |
register or
log in
Hollywood
Posted: Fri Feb 19, 2010 6:34 am |
| Newly registered Member |
Joined: Tue Feb 16, 2010 12:46 am Posts: 7 Has thanked: 0 times Been thanked: 0 times
I like the small bath/shower screen, what make is it,cost and where did you purchase it?
| Top |
register or
log in
siraz
Posted: Sat Feb 20, 2010 11:35 pm |
| Senior Member |
Joined: Fri May 02, 2008 4:18 pm Posts: 359 Location: everywhere Has thanked: 34 times Been thanked: 0 times
| Top |
register or
log in
royaloakcarpentry
Posted: Sun Feb 21, 2010 4:49 pm |
| Senior Member |
Hi Hollywood
the client supplied all the bathroom fittings and tiles. I prefer to work that way because then they actually know it is the exact bath etc that they want.
| Top |
register or
log in
davemulheran
Posted: Mon Feb 22, 2010 7:57 pm |
| Senior Member |
Joined: Mon Feb 15, 2010 2:59 pm Posts: 403 Location: Kent Has thanked: 28 times Been thanked: 17 times
Nice work mate
I have just moved in to a new house (1880's cottage) in Paddock Wood area
The bathroom needs gutting and replacing.. I was thinking of getting a wetroom fitted.. alongside a bath
are they easy to install? have you any pics of your jobs with a wet room fitted??
could be some work in it for you
cheers
Dave
| Top |
register or
log in
royaloakcarpentry
Posted: Mon Feb 22, 2010 8:18 pm |
| Senior Member |
To put it simply, yes they are easyish to install if you have done them but they are hard if you haven't and also don't have much of an idea.
You can have a bath in a wetroom. Not all wetrooms are open all areas. We have done them with raised shower areas and level shower areas behind glass.
Waste water isn't a problem because if you can't get the fall, then you can use a pump to get rid of it. £500 plus for pump plus fitting but well worth it to get finished article.
Haven't got any pics as all the ones I have been involved on have been on a sub-contract basis. I rarely take pics of sub-contract jobs because it isn't my work, so to speak.
I could probably get reference from client though.
| Top |
register or
log in
